Hyundai ELantra ATF follow up
by flinter. 07/17/19 10:14 AM
Poor Bill
by 4WD. 07/17/19 10:05 AM
Cadillac parked for 25 years...
by mattwithcats. 07/17/19 09:52 AM
Sumitomo Encounter Tires
by parshisa. 07/17/19 09:40 AM
API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
drnc, blackseven, EdK, guru2019, MBhuntington
68685 Registered Users
93 registered members (2015_PSD, ad244, alchargo, Alfred_B, 14Accent, 4WD, 6 invisible), 2,114 guests, and 26 spiders.
Topics291,984
Posts5,014,591
Members68,685
Most Online2,967
Mar 10th, 2019
just started another kreen cycle.. #2914014
02/20/13 08:02 PM
02/20/13 08:02 PM
TEXAS
electrolover Offline OP
TEXAS
I just added my first dose to the current fill in my F150. Half in the gas and half in the oil. Never added it to gas before..
Anyway my current fill has 800 miles on it and still looks like new oil. The oil never gets very dark on the stick with 5k ocis so I will be monitoring color as one point of reference. I will also be taking oil fill pics and disectecting the filter afterward. I have current fill hole pics for reference.
My plan is to run 4 quarts threw the engine, both in the gas and oil in this oci. But that is subject to change depending on other factors. I hope this becomes a thread filled with remarkable results!
2004 F150 5.4 160k-Castrol TXT 5/40, Distance+ 3410-KREEN
2004 Explorer 4.0 130k-PU 5w30, Distance+ 3410
Re: just started another kreen cycle.. [Re: electrolover] #2914024
02/20/13 08:08 PM
02/20/13 08:08 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
So you added Kreen to oil with 800 miles on it?
And its the same oil you always use so you will know by the stick if its unusually dark?
How long do you plan to leave it in the oil?
06 Escalade 6.0L LQ9 AWD 167k M1 0w40
03 Maxima 3.5L POS 170k ST HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
Re: just started another kreen cycle.. [Re: electrolover] #2914033
02/20/13 08:20 PM
02/20/13 08:20 PM
TEXAS
TEXAS
It evaporates so im going to add more when the oil level drops back to full or 1000 miles, oci legth depends on the condition of the oil, but im aiming for 4k
Fyi every oil I have ran in it stayed pretty clean on the stick. The engine has no sludge, just varnish so there is really nothing for it to dissolve that would discolor it. See my other thread on page 2 or 3 labeled 5.4 with varnish for reference pics.
So far I have ran PP, PU, synpower, napa syn, Formula shell syn, gtx hm, etc in this truck. The darkest drains were when MMO or Kreen was added to the oil.
It has a 7 quart sump btw, and its my opinion that the extra capacity helps the oil to look clean longer.
Re: just started another kreen cycle.. [Re: electrolover] #2914214
02/21/13 12:04 AM
02/21/13 12:04 AM
North Coast
Doog Offline
Doog  Offline
North Coast
What are you trying to accomplish?
The difference between a beer and your opinion is that I asked for a beer... well except for just now..Coffee2
Re: just started another kreen cycle.. [Re: electrolover] #2914224
02/21/13 12:11 AM
02/21/13 12:11 AM
TEXAS
TEXAS
Get rid of varnish and clean ring pacs.
Pulling the vc is a pain, so before and afters of the internals are probably not going to happen and pulling the plugs is risky so compression tests are not going to happen either. So the only thing we have for reference is oil fill hole pics, mpg, and filter inspection.
Re: just started another kreen cycle.. [Re: electrolover] #2914226
02/21/13 12:17 AM
02/21/13 12:17 AM
TEXAS
TEXAS
Heres the fill hole before. Its got some varnish on the phaser and timing cover as you can see.
Re: just started another kreen cycle.. [Re: electrolover] #2914313
02/21/13 06:18 AM
02/21/13 06:18 AM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
Doesn't look bad. With 160k I wouldn't worry about it. Thanks for sharing the pictures.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: just started another kreen cycle.. [Re: electrolover] #2914322
02/21/13 07:19 AM
02/21/13 07:19 AM
Saskatoon canada
Clevy Offline
Clevy  Offline
Saskatoon canada
My old 2v had chocolate come out for the first 15000 miles I had it. I was using Amsoil at the time. After those 3 oil changes I couldn't get the oil even black with 5000 mile(8000km) oil changes. That included about 30,15 pound bottles of nitrous run through it,dyno tuning and 5 test and tune nights as well as 3 street legal racing nights.
It it ain't broke.........
2006 Charger RT
Miles x 2 per oil filter
Re: just started another kreen cycle.. [Re: electrolover] #2914351
02/21/13 07:57 AM
02/21/13 07:57 AM
TEXAS
TEXAS
Like I said im running four qts of kreen through this engine.
Re: just started another kreen cycle.. [Re: electrolover] #2926481
03/03/13 12:23 PM
03/03/13 12:23 PM
TEXAS
TEXAS
1150 miles in. The oil level has dropped back to full and it no longer smells like kreen anymore. Here's a pick of the stick. Pretty clean. Added another 1/2 qt to he gas and oil.
Re: just started another kreen cycle.. [Re: electrolover] #2926489
03/03/13 12:34 PM
03/03/13 12:34 PM
TEXAS
TEXAS
Todays fill hole pics
Re: just started another kreen cycle.. [Re: electrolover] #2932467
03/08/13 11:25 AM
03/08/13 11:25 AM
SE PA
Trajan Offline
Trajan  Offline
SE PA
Originally Posted By: electrolover
They don't have pics because it doesn't work. But that's not to the purpose here. They keep startng threads to get people talking about this garbage.
So where are they? The before pics?
Lack of harm is not proof of benefit.
There are in fact two things, science and opinion; the former begets knowledge, the later ignorance. Hippocrates
Re: just started another kreen cycle.. [Re: electrolover] #2932469
03/08/13 11:29 AM
03/08/13 11:29 AM
TEXAS
TEXAS
My before pics are at the top of the thread. The othe pics are after using kreen again. I will post more pics every time I add more kreen.
Why are you bringing stuff in from another thread? Troll!
Re: just started another kreen cycle.. [Re: electrolover] #2932658
03/08/13 03:17 PM
03/08/13 03:17 PM
NY
demarpaint Offline
demarpaint  Offline
NY
I must have missed this thread, thanks for posting.
God Bless Our Troops
Re: just started another kreen cycle.. [Re: demarpaint] #2932841
03/08/13 05:53 PM
03/08/13 05:53 PM
TEXAS
TEXAS
So hows your kreening goin?
