Oil recommendation for 2014 2.5l Suburu Forester
by tomartomau - 12/13/19 10:50 PM
General RT43 or Conti TrueContact Tour
by Propflux01 - 12/13/19 10:16 PM
Mobil 1 0W-40, 2820 Miles, 2000 Mercedes E55 AMG
by Fotoflame - 12/13/19 09:48 PM
Streaming question
by loneryder - 12/13/19 09:43 PM
Anyone use 75w-85 instead of 75w-90
by jqgz - 12/13/19 09:42 PM
Cooper Discoverer AT3 4S - Thumbs Up!
by Nick1994 - 12/13/19 09:24 PM
Vortex 6.0 water pump
by chilson450 - 12/13/19 08:51 PM
Transmission fluid dilemma, need advice
by Sumo91 - 12/13/19 08:49 PM
Should I replace the Sonata?
by Nick1994 - 12/13/19 08:20 PM
Best P185/65R15 on the market? (+Low RR)
by Vern_in_IL - 12/13/19 08:17 PM
15 focus oil choice
by gabriel9766 - 12/13/19 07:58 PM
Building Up a New Stash
by Mr_Luke - 12/13/19 07:19 PM
acdelco DEXOS2 made by
by jkhawaii - 12/13/19 06:54 PM
UOA Corvette Z06 LS7
by randomhero439 - 12/13/19 05:34 PM
CCA va Reserve Capacity
by Gebo - 12/13/19 04:51 PM
Key fob 3v
by Duffyjr - 12/13/19 04:47 PM
car fax Diy uploads
by WhyMe - 12/13/19 04:43 PM
Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count
by thescreensavers - 12/13/19 04:34 PM
Penrite base oils
by KiwiBiker - 12/13/19 04:31 PM
chadder1313, Sumo91, CleanSump, Phillip0web, puppykat33
70121 Registered Users
47 registered members (carlprop, CARJ, clinebarger, addyguy, 14Accent, 6 invisible), 930 guests, and 22 spiders.
Topics298,784
Posts5,141,023
Members70,121
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
Best oil weight for 1977 Chevy Monte Carlo 305 #2932316 03/08/13 07:47 AM
J
jhammer382 Offline OP
J
Hey Everyone,
Trying to get some insight on the best weight oil for my car. Its a 1977 Chevy Monte Carlo with the 5.0/305 2bbl carbuerator with 66,000 original miles. It is the original engine that was supposedly freshened about 15,000 miles ago, but not sure exactly what was done to it. I have a feeling its just new seals. Completely stock minus headers.
The car does not appear to leak or burn any oil. It does sit in a garage for periods of time as its not a daily driver. I was thinking a 10w-40 or 20w-50. I run 20w-50 in my other vehicle which has an older Chevy 350 that has worn valve seals and does burn a tad of oil. It likes it, but feel that may be too heavy for the 305.
What do you all think? And this is non-synthetic oil.
Thanks for the help in advance!
Re: Best oil weight for 1977 Chevy Monte Carlo 305 [Re: jhammer382] #2932319 03/08/13 07:52 AM
F
Falcon_LS Offline
F
Maybe consider a 5W-40 like Rotella T6?
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
05 Envoy: XG9837
Motorcraft 5W-50:
18 Mustang GT: XG10575
Re: Best oil weight for 1977 Chevy Monte Carlo 305 [Re: jhammer382] #2932332 03/08/13 08:13 AM
B
Bottom_Feeder Offline
B
It doesn't need anything other than the 10w40 the manual calls for. 20w50 is too heavy for a non-DD in Jersey's climate. Hopefully whoever rebuilt it replaced the soft factory cam.
T6 may not be a bad choice at all.
Re: Best oil weight for 1977 Chevy Monte Carlo 305 [Re: jhammer382] #2932333 03/08/13 08:14 AM
M
mrsilv04 Offline
M
10w-30 Rotella or 10w-30 Rotella T5 synthetic blend.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Best oil weight for 1977 Chevy Monte Carlo 305 [Re: jhammer382] #2932335 03/08/13 08:16 AM
F
FL_Rob Offline
F
I'd go for a heavy duty 30 ,such as Rotella T5 10w30. With low miles and what sounds like a non-leaker, you can go with a nice Mobil 1 in 0w40 flavor.The ZDDP is what you're after with this engine,not just a thicker grade.
Edit:beat me to it mrsilv04
Re: Best oil weight for 1977 Chevy Monte Carlo 305 [Re: jhammer382] #2932336 03/08/13 08:17 AM
dave1251 Offline
5W-30.
don't use.
Re: Best oil weight for 1977 Chevy Monte Carlo 305 [Re: FL_Rob] #2932338 03/08/13 08:18 AM
dave1251 Offline
Nope. Myth's never die on the internets.
don't use.
Re: Best oil weight for 1977 Chevy Monte Carlo 305 [Re: jhammer382] #2932397 03/08/13 09:16 AM
R
racer12306 Offline
R
I had an 85 Monte SS with the L69 and it ran just fine on normal 10w30. Good oil pressure, no burnoff.
16 Ford Focus/2.0/6A
04 Dodge Neon SXT/2.0/MTX
17 Chrysler Pacifica/3.6/9A
Re: Best oil weight for 1977 Chevy Monte Carlo 305 [Re: Falcon_LS] #2932414 03/08/13 09:28 AM
Bandito440 Offline
That's what I would use. Great stuff.
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
Re: Best oil weight for 1977 Chevy Monte Carlo 305 [Re: jhammer382] #2932441 03/08/13 09:56 AM
Nickdfresh Offline
I'd just use Quaker State Defy 10W-30 or 10W-40, or maybe MaxLife 10W-40...
Re: Best oil weight for 1977 Chevy Monte Carlo 305 [Re: jhammer382] #2932474 03/08/13 10:31 AM
O
Oldswagon Offline
O
My brother has a 1976 350-2bbl Chevy, basically stock. We've run 10W30 HD oil in it for years with good success.
Re: Best oil weight for 1977 Chevy Monte Carlo 305 [Re: jhammer382] #2932515 03/08/13 11:31 AM
E
electrolover Offline
E
A high mileage 10/30 or rotella T5 10/30 would be just fine. No need for 20/50!
Re: Best oil weight for 1977 Chevy Monte Carlo 305 [Re: jhammer382] #2932524 03/08/13 11:39 AM
U
umungus1122 Offline
U
Any 5w-30 will do. HM if you're worried about it leaking.
'95 Chevy 1/2t 305 208k -NexGen Maxlife 5w-30, Wix filter
'04 Crown Vic 95k Maxlife full syn 5w-20
Re: Best oil weight for 1977 Chevy Monte Carlo 305 [Re: dave1251] #2932531 03/08/13 11:51 AM
Clevy Offline
Ha. No kidding. 1100 posts and you'd think he woulda absorbed something.
2006 Charger RT
Miles x 2 per oil filter
Re: Best oil weight for 1977 Chevy Monte Carlo 305 [Re: Clevy] #2932538 03/08/13 11:55 AM
M
maybehabitformin Offline
M
Any 5w30 you have less start up wear and the same thickness on the top end its a no brainer to me. I would use Defy myself It has higher zinc.
Page 1 of 3 1 2 3
