Any sellers on amazon for Honda A02?
by BTLew81. 07/18/19 03:44 PM
First SMR (MMR) slated to be built at Chalk River
by OVERKILL. 07/18/19 03:31 PM
Torque Specs for 2004 Dodge Ram transfer case
by diyjake. 07/18/19 02:15 PM
OAT ad NOAT
by CCI. 07/18/19 02:06 PM
30 years clean & sober today.
by Papa Bear. 07/18/19 02:03 PM
What is high output AC?
by Fitz98. 07/18/19 12:45 PM
Killed my receiver
by Quattro Pete. 07/18/19 12:35 PM
I did it! Put Straight HD30 in the PSD...
by racin4ds. 07/18/19 12:34 PM
Bobcat S630 engine oil
by Spdfrk1990. 07/18/19 12:09 PM
737 max... what now?
by Tdog02. 07/18/19 11:46 AM
Picked up a Hyundai oil filter from WM
by mclasser. 07/18/19 11:29 AM
Mobil1 20w50 Vtwin in a tuff torq K61
by gman2304. 07/18/19 10:47 AM
4t outboard W rating question
by 1978elcamino. 07/18/19 10:27 AM
Top three based on known specs.
by sloinker. 07/18/19 10:24 AM
Harbor freight 25% coupon
by Fitter30. 07/18/19 10:11 AM
Going to try longer OCI.
by mctmatt. 07/18/19 10:06 AM
diagnosing a/c problem
by matrass. 07/18/19 09:49 AM
Shaz, Grousebeater, RoyD, clonis, golddots
68699 Registered Users
104 registered members (Alfred_B, aquariuscsm, AandPDan, andyd, ArrestMeRedZ, AZjeff, 10 invisible), 2,258 guests, and 23 spiders.
Topics292,035
Posts5,015,729
Members68,699
Most Online2,967
Mar 10th, 2019
Page 4 of 9 1 3 4 5 9
Re: Restore Experiment [Re: Phishin] #2931804
03/07/13 07:02 PM
03/07/13 07:02 PM
North TX
RTexasF Offline
RTexasF  Offline
North TX
It has also worked for me in years past. I bought and sold old beaters driving some for a while prior to selling them. Restore was used at each oil change in the oil slurpers and it always worked positively. Consumption and smoke was reduced and the old dogs sounded better and ran better. It's a last ditch effort but it worked for me.
Re: Restore Experiment [Re: Trajan] #2931812
03/07/13 07:11 PM
03/07/13 07:11 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Originally Posted By: Trajan
Ehh, Restore didn't impress me when I tried it.
Maybe my problems better matched up to what Restore could do vs. whatever you had going on when you tried it. Just a guess tho.
Let's see.
Restore compression is one of the claims. It failed, thus it didn't impress me. ARX did not fail.
It did, however, make the oil more colorful when I drained it.
I don't think it will clog your filter either.
Just couldn't resist the hijack could you.
Re: Restore Experiment [Re: Trajan] #2931823
03/07/13 07:29 PM
03/07/13 07:29 PM
Washington
KeMBro2012 Offline
KeMBro2012  Offline
Washington
Let's see.
Stuck rings -> ARX
Worn rings and/or scuffed cylinder walls -> Restore
One "cleans ring packs" while the other fills in scratches and scuffs, so it's no wonder one would work where the other failed and there would be little or no overlap in their success stories. [censored], they work so differently that it's even possible that an engine with both stuck rings and scuffed cylinder walls would fail to see improvement with either product but vastly improve by running both; not that I'd ever suggest adding multiple additives.
Re: Restore Experiment [Re: KeMBro2012] #2931932
03/07/13 09:09 PM
03/07/13 09:09 PM
NY
demarpaint Offline
demarpaint  Offline
NY
True. But a treatment with Kreen or MMO added to the oil then change it, and a follow up OCI with Restore might do the trick in your example. Running both products at the same time is not a good idea.
A Kreen Piston soak, change the oil and add Restore might be a fast way to get good results too. Beaters can be fun to experiment with.
God Bless Our Troops
Re: Restore Experiment [Re: Phishin] #2931945
03/07/13 09:26 PM
03/07/13 09:26 PM
Indiana
Phishin Offline OP
Phishin  Offline OP
Indiana
Demarpaint.....
Why is Restore only for an engine on its last leg? What will it do to my engine if I keep Restore in my oil for the next 5 oil changes/25k miles?
Just wondering....
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: Restore Experiment [Re: Phishin] #2932207
03/08/13 05:57 AM
03/08/13 05:57 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Demarpaint.....
Just wondering....
If you have scored cylinder walls or wear it will help. If your engine is in good shape it will do nothing. An engine with scored cylinder walls, and excessive wear causing burning and blowing oil, is on its last in my opinion. Some people might feel otherwise it is only my opinion. The comment wasn't meant to be offensive. I could have substituted the words "worn engine" with "on its last legs," or used "tired engine" now that I think of it. But I think you get my point.
I'm just curious, have you tried MoS2 in that engine yet?
Re: Restore Experiment [Re: Trajan] #2932260
03/08/13 07:40 AM
03/08/13 07:40 AM
TEXAS
electrolover Offline
TEXAS
Let's see.
Omfg! Now your snake oil not only cleans it fills in scored cylinders?
That's complete hog wash. boxing
2004 F150 5.4 160k-Castrol TXT 5/40, Distance+ 3410-KREEN
2004 Explorer 4.0 130k-PU 5w30, Distance+ 3410
Re: Restore Experiment [Re: electrolover] #2932426
03/08/13 10:37 AM
03/08/13 10:37 AM
Indiana
Phishin Offline OP
Phishin  Offline OP
Indiana
What are you talking about? I never said the Restore did any cleaning. Never. I'm sure Trajan was just talking about the color of Restore. If you would have had any ACTUAL experience with it before spouting off, you would have known that.
But I did make three claims....the first two are absolutely legit and provable based on previous experiences:
1.) After adding Restore, I immediately drove the truck 400 miles down the highway. It burned half the oil it used to burn before adding Restore on this same exact trip.
2.) Driving around town the next 700 miles, I've only burned 1/3 quart. That is a big reduction in oil consumption as well.
3.) Although I have no data to support this, my engine does run A LOT smoother. At idle and going down the road.
I never said it cleaned anything electro. If you read a bit more carefully, you'll see that people were discussing the differences between stuck rings and worn out rings/cylinder walls and how AutoRX and Restore might possible address one of these issues, but not both.
It is possible that your compression was low due to valve problems, not with rings. I don't think Restore could fix a valve problem....like your valves not sealing well. This would cause low compression, but Restore wouldn't help it. But maybe you have all sorts of deposits on your valves and AutoRx cleaned them all up? I don't know. Just a guess.
Re: Restore Experiment [Re: Phishin] #2932429
03/08/13 10:43 AM
03/08/13 10:43 AM
TEXAS
TEXAS
My comment wasn't meant for you.
Restore does work for old beaters. I have used it too.
Re: Restore Experiment [Re: Phishin] #2932433
03/08/13 10:49 AM
03/08/13 10:49 AM
NY
demarpaint Offline
demarpaint  Offline
NY
^^ I think Electro was just having fun that's all.^^ Some members want proof, and consider testimony worthless, yet when asked to back up claims they make with proof, they don't have any. Oh well. I for one believe everything you've said because I had observed similar results. With some of these products all there is, is testimony, you have to take it for what its worth, note the source, and if there is a hidden agenda. Those who want to believe it might benefit if they ever encounter a similar situation. Those who care not to believe it, well it's their loss.
Re: Restore Experiment [Re: Phishin] #2932449
03/08/13 11:06 AM
03/08/13 11:06 AM
TEXAS
TEXAS
No I just get tired of FM's buddies pushin his garbage in every additive thread. A motor can be absolutely wore out and they come in saying "buy this it works! Nothing else does" and when it doesn't work their answer is always the same "you didn't use it right" or " buy more".
Restore is good at what it does, filling voids until you can get a new engine or new car. But because it rivals an internet only supplied additive that is only advrtised by word of mouth and "testimonials" people feel the need to pollute every additive thread with FM's propaganda
Re: Restore Experiment [Re: Phishin] #2932461
03/08/13 11:19 AM
03/08/13 11:19 AM
SE PA
Trajan Offline
Trajan  Offline
SE PA
[quote=Trajan]
Nope, it was low due to rings. It failed. ARX did not.
Lack of harm is not proof of benefit.
There are in fact two things, science and opinion; the former begets knowledge, the later ignorance. Hippocrates
Re: Restore Experiment [Re: Phishin] #2932463
03/08/13 11:20 AM
03/08/13 11:20 AM
Indiana
Phishin Offline OP
Phishin  Offline OP
Indiana
Gotcha electrolover.
I agree with you 100%. I never heard much about Restore on here, so that's why I wanted to make a thread about it.
Of course, I expected to hear the AutoRx cheerleaders give their victory cry. I get tired of the AutoRx pollution in every thread too in this sub-forum, but it just digs them deeper into the grave, I think. Makes them look desperate.
Enough people have told me that "ring pack cleaner" doesn't do a darn thing, that I believe them....and most of the others that report success with it, are "anti-additive guys....well, except AutoRx....it really does work".
Anyhow, back to our regularly scheduled program....
Anything more I can report regarding Restore I will.
But I am curious if you all think running Restore in my engine for 5 OC's....for 25k miles will cause it any harm/damage.
Because in actuality, with or without Restore, this engine could die tomorrow or go another 80k miles. Who knows with these old Chevy 350's....and mine's "only" got 180k on it. Although, most of it's life it was abused.
Re: Restore Experiment [Re: Phishin] #2932477
03/08/13 11:32 AM
03/08/13 11:32 AM
TEXAS
TEXAS
Another long block is like $1500. Don't worry about the mule, just load the cart
Re: Restore Experiment [Re: Phishin] #2932530
03/08/13 12:51 PM
03/08/13 12:51 PM
NorthEast
Vikas Offline
Vikas  Offline
NorthEast
I too want to know the harmful effects of using Restore. In my opinion needing it for every oil change is not harmful effect. Under what condition, would it make things worse than before?
Phishin, do you have pre-Restore compression readings? Your empirical evidence of reduced oil consumption in itself is enough but the change in compression will corroborate better running of ht engine.
