What is high output AC?
by Fitz98. 07/18/19 12:45 PM
Killed my receiver
by Quattro Pete. 07/18/19 12:35 PM
I did it! Put Straight HD30 in the PSD...
by racin4ds. 07/18/19 12:34 PM
Bobcat S630 engine oil
by Spdfrk1990. 07/18/19 12:09 PM
737 max... what now?
by Tdog02. 07/18/19 11:46 AM
Picked up a Hyundai oil filter from WM
by mclasser. 07/18/19 11:29 AM
Mobil1 20w50 Vtwin in a tuff torq K61
by gman2304. 07/18/19 10:47 AM
4t outboard W rating question
by 1978elcamino. 07/18/19 10:27 AM
Top three based on known specs.
by sloinker. 07/18/19 10:24 AM
Harbor freight 25% coupon
by Fitter30. 07/18/19 10:11 AM
Going to try longer OCI.
by mctmatt. 07/18/19 10:06 AM
diagnosing a/c problem
by matrass. 07/18/19 09:49 AM
Any friends of StevieC here ?
by Kjmack. 07/18/19 09:29 AM
Oil change interval on 70 Chevelle
by 007. 07/18/19 09:20 AM
New to me 2018 Grand Caravan 3.6 weight questions.
by racinjason. 07/18/19 07:38 AM
Help With 6L80E Fluid & Pan Replacement
by Sierra048. 07/18/19 06:39 AM
Shaz, Grousebeater, RoyD, clonis, golddots
68699 Registered Users
94 registered members (01rangerxl, 53' Stude, 2009Edge, ABerns, 2015_PSD, aquariuscsm, 9 invisible), 2,147 guests, and 27 spiders.
Topics292,030
Posts5,015,548
Members68,699
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: Auto RX re [Re: Trajan] #2932472
03/08/13 11:31 AM
03/08/13 11:31 AM
TEXAS
electrolover Offline
TEXAS
Originally Posted By: Trajan
Originally Posted By: electrolover
http://www.davemanuel.com/investor-dictionary/snake-oil-salesman/
I found this interesting. Sounds like it was written about a certain product
This isn't a kreen thread.
Is that the best come back your daddy could come up with?
2004 F150 5.4 160k-Castrol TXT 5/40, Distance+ 3410-KREEN
2004 Explorer 4.0 130k-PU 5w30, Distance+ 3410
Re: Auto RX re [Re: electrolover] #2932703
03/08/13 03:55 PM
03/08/13 03:55 PM
SLO, CA
eliminator Offline
eliminator  Offline
SLO, CA
They don't have pics because it doesn't work. But that's not to the purpose here. They keep startng threads to get people talking about this garbage.
old accounts show up after years of being gone just to mention the product....
That's not fishy at all......NOT!
I just explained my proof that ARX worked in my case. Were all the numbers too hard for you to understand?
Re: Auto RX re [Re: roadrunner1] #2932747
03/08/13 04:43 PM
03/08/13 04:43 PM
TEXAS
TEXAS
No the fact that you haven't been here in years and then show up to plug the product is what I don't understand. ....
Re: Auto RX re [Re: eliminator] #2932753
03/08/13 04:47 PM
03/08/13 04:47 PM
SE PA
Trajan Offline
Trajan  Offline
SE PA
Don't get into it. He's never used it. And just ignores all threads that are success stories except to trash them.
"This infighting over a product that has caused a lot of strife on the boards over the years is going to stop. Otherwise threads are going to come down and people on both sides of the argument will be facing a ban."...JHZR2
Lack of harm is not proof of benefit.
There are in fact two things, science and opinion; the former begets knowledge, the later ignorance. Hippocrates
Re: Auto RX re [Re: electrolover] #2932778
03/08/13 05:05 PM
03/08/13 05:05 PM
Colorado
Mystic Offline
Mystic  Offline
Colorado
Based on what I know now I think before I tried any engine cleaner I would see how clean I might be able to get the engine by just using a motor oil that can clean well. For example, there is evidence that Pennzoil Platinum and Pennzoil Ultra may be able to clean well. You can't go wrong using an approved motor oil. If you had been using some conventional motor oil the Pennzoil synthetic would just be somewhat more expensive.
Am I trying to go off topic? No I am not. If you felt the engine still needed some cleaning you could use Auto-RX (or some other cleaner). Or an idle only engine flush instead of a drive around cleaner. Using the cleaning motor oil might assist the Auto-RX to do its job better. You could use the Pennzoil synthetic and if the engine needed more cleaning you could use a conventional oil with the Auto-RX at the next oil change.
I am not trying to go off topic at all. This post is about Auto-RX. But some people might not want to use a special engine cleaner and there are some motor oils that might be able to clean well enough. And the motor oil is approved.
If a person had seal leaks develop after they had switched to a synthetic motor oil I will say that Auto-RX seemed to stop a seal leak on a car I owned. I have no proof of that beyond the fact that the seal leak stopped after I did the Auto-RX cleaning.
I am trying to be 100% fair and honest here. Everybody knows that I did not suddenly appear out of nowhere after not posting for an age and I am not trying to promote a certain product. If you don't like the Pennzoil maybe try Mobil 1. Or maybe try a good cleaning motor oil along with Kreen or MMO.
I am trying to stay on topic but I am also trying to assist somebody who may be trying to clean a dirty engine. I believe that Auto-RX may have some ability to stop seal leaks but as for its cleaning ability I think the jury is still out.
I suppose this reply could be considered a counter argument but debate for and against a given product is allowed, correct? And I think I stayed reasonably on topic and I even gave some praise to Auto-RX. So let us see if somebody will now attack me over what I consider to be a fair and unbiased reply.
Re: Auto RX re [Re: Trajan] #2932938
03/08/13 07:45 PM
03/08/13 07:45 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Since that post you have become even more provocative but we all know what your playing at.
Its not going to work chief.
Re: Auto RX re [Re: roadrunner1] #2933186
03/09/13 12:37 AM
03/09/13 12:37 AM
UT
Bill in Utah Offline
Global Moderator
Global Moderator
UT
Why does every thread have to get PERSONAL instead of staying on subject?
Locked like the other one.
Page 2 of 2 1 2
