Mater Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
118 registered members (2015_PSD, 555, 97f150, 69Torino, 2012AccentSE, 64bawagon, 16 invisible), 2,104 guests, and 59 spiders.
Topics286,156
Posts4,903,136
Members67,565
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
Water Injection in Old/Tired Chevy 350 TBI #2922042
02/27/13 11:11 AM
02/27/13 11:11 AM
Indiana
Phishin Offline OP
Phishin  Offline OP
Indiana
I'm running some scenarios through my head regarding a water injection system on my oil burning Chevy 350 TBI.
My hope is to keep deposits down in the combustion chambers. I've gotten rid of bad pinging/detonation in the past giving the engine a steam cleaning by pouring water down the intake. But I'm still currently fouling a plug in #1 quite often and I'm tired of spending the money to keep PEA in my tank all the time and filling up with Premium gas as well.
I've read on line that you want to keep water to under 10-15% of fuel burning otherwise you risk contamination of the oil with water.
So, I have a 22 gallon gas tank. So one gallon of water/full tank of gas is the ratio I'm shooting for, which is about a 5% water/gas ratio. Should be safe, right?
I'm thinking of using a hyperdermic needle perhaps to create an inlet in either my brake booster hose or into the PCV line....just before either line connects to the intake. What do you think of this idea?
Lastly, do you think either of these vacuum sources will have enough force to suck water out of a gallon jug through some tubing? Or am I wasting my time?
Thank you in advance.
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: Water Injection in Old/Tired Chevy 350 TBI [Re: Phishin] #2922051
02/27/13 11:18 AM
02/27/13 11:18 AM
Texas
440Magnum Offline
440Magnum  Offline
Texas
Self-activiated (vacuum) water injection rarely works quite the way you hope it will. For one thing, you really only need to be injecting water under heavy load / high RPM where the pinging occurs, and that's where vacuum is NOT going to help you! You'll be injecting the most water when you're coasting or idling, and that's going to a) not help pinging, and b) contaminate the oil the most.
Effective water injection uses a pump, controller, and solenoid shutoff valve to atomize the water and deliver it only when the RPMS are up and the vacuum is down (manifold absolute pressure is the highest, in other words).
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: Water Injection in Old/Tired Chevy 350 TBI [Re: 440Magnum] #2922058
02/27/13 11:27 AM
02/27/13 11:27 AM
Lakeside CA
another Todd Offline
Lakeside CA
Excellant answer. +1
Re: Water Injection in Old/Tired Chevy 350 TBI [Re: Phishin] #2922062
02/27/13 11:29 AM
02/27/13 11:29 AM
Massachusetts
Zaedock Offline
Zaedock  Offline
Massachusetts
Go up heat range on the spark plug for that cylinder. It will help lengthen the time between foulings.
You may want to look into replacing the valve seals too. They're cheap and not too difficult to do on a SBC. You can use a piece of rope in lieu of air to the cylinder to keep the valve from falling in.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Water Injection in Old/Tired Chevy 350 TBI [Re: Phishin] #2922068
02/27/13 11:35 AM
02/27/13 11:35 AM
NE
jegs Offline
jegs  Offline
NE
Have you ever checked the ignition timing? It is adjustable and must be set on these engines. If it is set to far advanced the engine will tend to be pingy.
Also have you replaced the intake gaskets. These engines are notorious for leaking water into the oil from bad intake manifold gaskets but sometimes there will be a leak from an intake port to the lifter valley and it will suck in oil. I have seen these engines go 250k without using oil so it could be an intake leak instead of piston ring wear especially since it only fouls one plug.
Re: Water Injection in Old/Tired Chevy 350 TBI [Re: jegs] #2922073
02/27/13 11:43 AM
02/27/13 11:43 AM
Indiana
Phishin Offline OP
Phishin  Offline OP
Indiana
The timing is correctly set. I've done it myself a few times, and check it occassionally. It's dead nuts on.
This cylinder always burned out. It did have a leaky intake maifold gasket. It was replaced. Nothing changed as far as oil consumption or that cylinder slowing down it's oil burning either. I think it's possibly a worn out/broken valve guide. Doesn't matter, because I'm not throwing any more money in this engine. When it dies, I'm installing a new GM crate engine for this truck. They are cheap. So, I'm gonna run this one out until she dies.
Re: Water Injection in Old/Tired Chevy 350 TBI [Re: 440Magnum] #2922074
02/27/13 11:47 AM
02/27/13 11:47 AM
Indiana
Phishin Offline OP
Phishin  Offline OP
Indiana
I'm not too concerned about having water in the combustion chamber when under high RPM load. My pinging is due from piston deposits, not high compression/performance mods. So, even if the engine is drinking some water only when it's idling or coasting....that's fine with me. Honestly. I just want to de-carbonize the pistons one more time by steam cleaning (pouring water down intake), and then hopefully use this water injection system as maintenance....instead of putting PEA in my tank constantly and buying 93 octane fuel.
If the piston tops are relatively clean from the water injection all the time I'm idling and coasting, it won't ping when I'm under load at high RPM's and with no water.
See what I'm saying?
Re: Water Injection in Old/Tired Chevy 350 TBI [Re: jegs] #2922078
02/27/13 11:51 AM
02/27/13 11:51 AM
North Coast
Doog Offline
Doog  Offline
North Coast
I would skip the water injection idea and try this:
1. Switch to 15w40 HDEO
2. Clean the TB and do a piston soak overnight with B12 Chemtool or similar.
3. Do a complete tune up (wires,cap, plugs,timing) and find a higher heat range spark plug and if possible a low voltage platinum style for the fouling cylinders.
4. Try MMO or Lucas upper cyl lube in your gas and see what happens.
5. Check your coil output
The difference between a beer and your opinion is that I asked for a beer... well except for just now..Coffee2
Re: Water Injection in Old/Tired Chevy 350 TBI [Re: Phishin] #2922091
02/27/13 12:02 PM
02/27/13 12:02 PM
Texas
440Magnum Offline
440Magnum  Offline
Texas
It still cleans better under load, so how about rigging a windshield-washer pump to squirt down the TB when you push a button? That way you could hit the button under load to clean it, then not be drinking water when its unloaded?
Re: Water Injection in Old/Tired Chevy 350 TBI [Re: Doog] #2922098
02/27/13 12:07 PM
02/27/13 12:07 PM
Indiana
Phishin Offline OP
Phishin  Offline OP
Indiana
Already done all that. Done so many piston soaks on that one cylinder, I should be locked up.
Never tried MMO or Lucas UCL in my gas tho. Sure, I'll give that a shot.
Coil is good too.
But thanks for the suggestions Doog.
Genius!! Except my washer pump isn't working...but now I have a legit reason to trouble shoot it. Sweet. Thanks 440!!
Re: Water Injection in Old/Tired Chevy 350 TBI [Re: Phishin] #2922111
02/27/13 12:11 PM
02/27/13 12:11 PM
North Coast
Doog Offline
Doog  Offline
North Coast
Then I would replace that one cyl valve seals and see what happens.
Re: Water Injection in Old/Tired Chevy 350 TBI [Re: Phishin] #2922113
02/27/13 12:14 PM
02/27/13 12:14 PM
WI
BurrWinder Offline
BurrWinder  Offline
WI
This all looks good, but yes, I agree with some of the others.. you have got something going on there that water injection is not really the right solution to I believe. Valve seals, rings, whatever - and actually the sad irony is the high octane fuel isn't helping ur carbon buildup one bit either, other than minimizing the ping - if it even does THAT.
Re: Water Injection in Old/Tired Chevy 350 TBI [Re: Phishin] #2922116
02/27/13 12:15 PM
02/27/13 12:15 PM
WI
BurrWinder Offline
BurrWinder  Offline
WI
You can even do the valve seals without pulling the head with compressed air and the cyl locked to TDC.
Re: Water Injection in Old/Tired Chevy 350 TBI [Re: BurrWinder] #2922118
02/27/13 12:16 PM
02/27/13 12:16 PM
North Coast
Doog Offline
Doog  Offline
North Coast
Have you tried a motormite spark plug non-fouler adapter?
http://www.dormanproducts.com/catalog/motormite/143-151SFinal.pdf#Page=3
Re: Water Injection in Old/Tired Chevy 350 TBI [Re: Phishin] #2922123
02/27/13 12:19 PM
02/27/13 12:19 PM
Hudson, NH
LeakySeals Online content
LeakySeals  Online Content
Hudson, NH
I've followed this truck for a while now. You gotta fix it or part ways with it. You coulda had that engine rebuilt for the oil and additives your dumping into it.
Seriously if you replaced the rings, quick hone, and some valve seals all would be fine. Take a couple of days. Do it. We will help you.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Page 1 of 4 1 2 3 4
