I decided to start this new post because nobody seemed to notice Falcon_LS's photographs in the post 'I tried Auto-RX for 1,500 miles...'
He said that he tried a special engine cleaning product for 22,000 miles (4 cleaning routines) and did not get much in the way of results. He physically cleaned parts of the engine and then he tried Pennzoil Platinum motor oil for about 3,800 miles. Sure he did some physical cleaning on the engine, but not that much. If you check out the photographs he took in the post 'I tried Auto-RX for 1,500 miles...' it is AMAZING how well the Pennzoil Platinum motor oil cleaned the engine.
I dare to say that the typical engine cleaning product will probably not do any better than the Pennzoil Platinum. I am not saying that the engine is perfectly clean, but it is greatly improved. Unless a person is blind they should be able to see the difference. I am impressed enough I am going to use Pennzoil Platinum in my next oil change.
To get even better results a person might combine the Pennzoil Platinum with Neutra, MMO or Kreen. Or do engine flushes with Amsoil nonsolvent engine flush or Lubegard nonsolvent engine flush before doing another oil change with Pennzoil Platinum.
Personally I will try just the Pennzoil Platinum by itself. If it turns really dark I will assume it is cleaning and maybe use a nonsolvent engine flush the next time I change the oil. But a few short OCI oil changes with Pennzoil Platinum might be enough to clean an engine.
Look for yourself at the photographs.
