Originally Posted By: vtecboy
I have a question:
Do you guys think the valve cover gasket that i just installed is damaged?.... I don't have money to spend money on a new gasket again.
i don't know what your gasket looks like or is made of, or how your valve cover is shaped. can't see any pics at the moment. but a valve cover gasket is not a critical part and unless the cover is deformed or something is should be very easy to seal. if the gasket is not deformed it should work. if you don't want to spend money on a new gasket, high temp RTV silicone should work provided you apply it properly. you may also want to check both mating surfaces to make sure nothing is affecting the sealing of the gasket. and because you mention it's the rear head, i would not be surprised the gasket might not sit correctly on the head because you cannot see back there.
also there are many items you should not use a torque wrench for. Just because a service manual has a torque value printed for a certain fastener does not mean you should use a torque wrench on it and tighten the fastener to that exact value. You need to understand what you are tightening or clamping and whether torque wrench should be used. a valve cover gasket is not a critical item that needs to be torqued or have excessive clamping force where you need to stretch the fasteners (you are not using torque-to-yield bolts on your valve cover). When a manual or whatever says only 35 inch-pounds, what that means in the real world is it's easy to over tighten the fastener and cause problems. this is typical of thin or soft gaskets and plastic parts where you can break the part by over tightening the fastener, such as plastic intake manifolds. in cases like this it's best to use a small 1/4" ratchet and do by feel and once the bolts or nuts just get snug and the gasket not being compressed then you do only 1/4 to 1/2 turn more at each fastener to evenly clamp the cover. then worst case if you didn't tighten it enough, you can re-tighten with no ill affects. in this case all you need is for the cover to seal against the head and if the gasket is placed properly over clean mating surfaces it will seal very easily. there is no oil pressure in there trying to force it's way between the head and valve cover so you do not need a lot of clamping force. and if anyone says to themself i can't judge by hand how tight/loose a fastener is or how well a part is clamped when we're talking this range of clamping force, that's a good indication you probably should not be turning wrenches on expensive things.
