Originally Posted By: doitmyself
Regarding antiseize, I talked to Permatex, but unfortunately I cannot find my notes. From my perspective, if one throws out all the exotic antiseizes, there are 3 basic types commonly available: Silver (copper/alumimum/graphite), copper, and Nickel.
From recollection, I remember him telling me:
- For vehicle use, all 3 can be used interchangeably.
- Copper has slightly higher temp. and conductivity (don't use copper near ABS sensors??)
- Nickel works "best", BUT is probably overkill ($$)for general use.
Again, best I can remember. Comments/disagreement welcome....someone else please call and report back!
EDIT: Contrary to Dantheman80's account of dielectric corrosion, Permatex states that their copper product is best for ALUMINUM heads! http://www.permatex.com/products/product...ubricant-detail click TDS
This over abundant info gives me headaches.
For spark plugs in aluminum heads, I use this aluminum/copper/graphite Permatex A-S:
"........Suggested Applications: For easy removal of spark plugs, cylinder head and exhaust head bolts; apply to anchor pins on brake assemblies, u-bolts and spring bolts, hinges, gears, chain, sprockets and rollers..."
For suspension and undercarriage bolts that are exposed to water spray and deicer chemicals, I use the Loctite Marine Anti-Seize.
http://www.henkelna.com/cps/rde/xchg/henkel_us/hs.xsl/product-search-1554.htm?nodeid=8797882515457
