My 02 Silverado uses a caliper pin with a rubber bushing at the end. I'm having a hard time reinserting the pins because the rubber bushing is stuck in the bore. The pins look like this:
The bushings go into the thinner part while the caliper rides on the middle thick part. Also on the other side where I managed to get the pins in, it took a lot of effort to slide the caliper and might worry if the outer pads start dragging or sticking.
Can I remove the end bushings? The rear disc brakes does not use this pin design .
