Just curious, guys on a question that's been bugging me. My car has the aluminum block engine but not the original radiator. What is in there now is a brass radiator to replace the original one that cracked its plastic. If I use a water/ethylene glycol mix that's 88%/12% instead of the recommended 50/50 mix, how much anti-corrosion property will that give? Reason for considering a weak solution is that I live in a warm climate and have no need for antifreeze quality. I believe the water pump bearings are sealed, hence no need for the lubricity of normal coolant strength. Your comments?
