Hello:
I got a V6 231 Buick motor that I just uprated the filter mount to accept 13/16 inch spin on filters (vs. the stock M18 mount, which offers little choice in filter types)
At anyrate I cross referanced a Car Quest 85049 filter as a nice upgrade, it is supposed to have an anti drain back valve, but I look at it at dont see the rubber valve behind each inlet hole.
Is there some other type of anti drain back valve that is not visiable, or is this filter missing it?
At anyrate I need an antidrain valve , it was specified for this engine, the filter mounts horizontaly.
Is the the Car Quest filter I bought a good quality? (assuming it has a hiden anti drain valve)
The engine has an uprated oil system (twice stock pressure). The very small orignal filter had the internals crushed as it could not handle the flow rate. (hence my quest for the larger filter, increased flow ability)
