The usual sobering reminder
by simple_gifts - 10/23/19 08:59 PM
usps says package delivered and no package
by motor_oil_madman - 10/23/19 08:12 PM
Walmart Penzoil Ultra 0W20 for $17.31
by danez_yoda - 10/23/19 08:10 PM
Just started going to the gy: questions.
by 14Accent - 10/23/19 07:53 PM
03 Tiburon delayed crank
by HyundaiAbuser - 10/23/19 07:36 PM
Replacing 1 Tire With A Smaller Size, Temporarily?
by Kevinmcc2 - 10/23/19 07:34 PM
Buggy Apple Software
by SubLGT - 10/23/19 07:24 PM
VGA Brand Oil Filter
by Robb. - 10/23/19 07:10 PM
GF6 etc
by double vanos - 10/23/19 06:52 PM
2018 crv.. 9k engine replacement
by Firehawk409 - 10/23/19 06:32 PM
Surprise - Tesla earns a surprise profit in Q3
by JeffKeryk - 10/23/19 06:12 PM
BMW now in on gigantic grills...
by wemay - 10/23/19 06:06 PM
98 Accord 4 cyl - P705 Code
by JeffKeryk - 10/23/19 05:54 PM
NEW: Motul Specific LL-01FE 5W-30
by The Critic - 10/23/19 05:21 PM
Got the Hyundai home
by ram_man - 10/23/19 05:12 PM
Pressure washer hose keeps failing...
by dlundblad - 10/23/19 04:42 PM
How much should I ask?
by cwilliamsws6 - 10/23/19 04:10 PM
Happy Birthday, "Wierd Al" Yankovic!
by eljefino - 10/23/19 03:49 PM
Havoline ProDS Syn 10W-30 $19.73 6-pack
by Jackson_Slugger - 10/23/19 03:02 PM
Wix Oil Filter Rating Question
by 02vito - 10/23/19 02:30 PM
noname, CMAMerc, ChevJames, Mando, Mridgeway85
69657 Registered Users
129 registered members (AndyB, aba4430, AandPDan, ammolab, 4WD, 15 invisible), 2,040 guests, and 24 spiders.
Topics296,410
Posts5,097,087
Members69,657
Most Online3,532
Jul 30th, 2019
Lucas Synthetic Oil Stabilizer #289999 07/02/05 09:48 AM
Crashbox Offline OP
I purchased a fair quantity of this pre-BITOG. Haven't used it in any vehicle yet and may not do so because of some evaluations/experiences with the non-syn variant on this board.
Maybe I'll send some in for a VOA, haven't found one on it yet...
I have, however, found a terrific use for it- oiling my bicycle parts! It's virtually water-clear.
I don't want to start a firestorm here but has anyone else used the synthetic stuff? Just curious.
Re: Lucas Synthetic Oil Stabilizer #290000 07/02/05 12:37 AM
MolaKule Offline
Global Moderator
Global Moderator
Haven't used it but it's similar to STP in that it has a high viscosity base oil with a few additives. Where STP uses OCP's, the base for Lucas is mostly high viscosity PAO's and dispersants.
But go ahead and do a VOA and see what if any elemental additives can be seen.
Re: Lucas Synthetic Oil Stabilizer #290001 07/02/05 02:45 AM
Crashbox Offline OP
Thank you for the info, MolaKule. I might just decide to send a VOA in. My suspicion, though, is that not too much may show element-wise but I could be wrong.
Maybe it's a clear fluid because they used "transparent molybdenum"- [Big Grin]
Re: Lucas Synthetic Oil Stabilizer #290002 07/03/05 10:03 PM
B
Bror Jace Offline
B
It was Bob who said years ago that most (all?) of Lucas Oil Stabilizer was bright stock ... a highly viscous petroleum component. He said that it had no, or almost no, barrier anti-wear adds.
If this is true, elemental analysis is going to be a bit disappointing and won't answer a lot of the questions you/we have.
MolaKule, OCPs? [Confused] I thought STP was mostly PIB - poly isobutane - but my memory for non-work stuff has been pretty lousy lately. [Embarrassed]
--- Bror Jace
Re: Lucas Synthetic Oil Stabilizer #290003 07/03/05 10:35 PM
MolaKule Offline
Global Moderator
Global Moderator
Many of the Olefin copolymers are made from the PIB series.
The olefin copolymer is made by the reaction of of one or more monomers (single molecular units) which is usually butylene and/or propylene. The polyisobutylene is a polymerized form of butylene.
Basically, it's related to the family of liquid rubbers and the thinner versions of tackifiers.
Lucas appers to be a mix of brightstocks and OCP's, very similar to the Xentec stuff.
Re: Lucas Synthetic Oil Stabilizer #290004 07/04/05 02:34 AM
B
bruce381 Offline
B
from
MolaKule
"Lucas appers to be a mix of brightstocks and OCP's, very similar to the Xentec stuff."
how do you know is thier data? I vote for 100% OCP.
bruce
Re: Lucas Synthetic Oil Stabilizer #290005 07/04/05 06:34 AM
MolaKule Offline
Global Moderator
Global Moderator
Because of the reactions with certain esters.
Re: Lucas Synthetic Oil Stabilizer #290006 07/05/05 06:38 AM
B
bruce381 Offline
B
Sorry I do not understand "reactions with certain esters" reaction to what with what.
How does that prove brighstocks and OCP?
I thought the Lucas was a OCP VII with possibly some ZDDP and or paratac.
bruce
Re: Lucas Synthetic Oil Stabilizer #290007 07/06/05 01:04 AM
MolaKule Offline
Global Moderator
Global Moderator
By using specific esters, one can determine if the base oil contains OCP thickeners or OCP VII's.
The ester causes the sample to polmerize at room temp via a polymerization reaction.
Anything not made with ethylene or propylene or butylene monomers will separate from the polymerized goo. Goo is my scientific term for "gellation."
I discovered this some time ago when developing, analyzing, and compounding esters and esterified additives.
Re: Lucas Synthetic Oil Stabilizer #290008 07/06/05 02:14 AM
B
bruce381 Offline
B
Very good trick I would like to know more, I have used the micro wave oven for ester testing hotter the more ester. Since most avalible OCP VII are only a samll percent OCP with the >80% balance a base oil if you weighted it all out you could get a good number on the amount of OCP.
bruce
Re: Lucas Synthetic Oil Stabilizer #290009 07/06/05 05:22 AM
MolaKule Offline
Global Moderator
Global Moderator
The actual fluids used and the exact processes are proprietary.
One thing you have to consider is, if they use a high molecular weight succinimide dispersant, this is an ester as well and you have to account for that which SF has done.
Re: Lucas Synthetic Oil Stabilizer #290010 07/09/05 08:38 PM
B
babydoggy Offline
B
Lucas stabilizer does not have any zinc or moly. I read this from their spokeperson in an interview. He would not state what it does have in it. There are other anti-wear additives. For the price they are charging I would hope it it does have unique additives. Maybe they are relying on viscosity to compensate for extreme pressure additives.
