Since my last grease gun failed (under warranty) I have been on the sear h for the perfect grease for my application. This is primary as a chassis/suspension lubricant but it also must function perefectly as a disc brake bearing lube and less than perfectly but well enough for virtually any other grease application on automobiles. At this point in tome primarily a ford truck with slicer universals and a Grand Prod but just as well on anything that I may end up working on.
After so.e thought I wanted a grease available easily and locally to maintain consistant lubrication, one that has good high and low temp properties and will work exceptionally we'll for ball joints and other suspension and steering components as well as disc brake (and maybe motorcycle) wheel bearings and u joints. Preferably with strong moly content.
Ended up with a tube of valvoline durablend. Can anyone comment on this grease? Also website States a slightly different temp range than the cartridge I purchased, should this be of concern?
