GunsInternational
by Yah-Tah-Hey - 02/19/20 03:39 PM
400hp VW Arteon confirmed for 2021
by wemay - 02/19/20 03:11 PM
redline 75W140
by mobilaltima - 02/19/20 02:50 PM
brake flush, upgrade to dot 4 or stay with dot 3
by apollo18 - 02/19/20 02:49 PM
I'm hoping it is the battery. 2016 Camry
by andyd - 02/19/20 02:48 PM
New Zoro 20% off $75 or more
by bullwinkle - 02/19/20 02:24 PM
New platinum beta ratio?
by mpgo4th - 02/19/20 01:40 PM
Lubrizol GF-6 Video Interview w/ Martin Birze
by ARCOgraphite - 02/19/20 01:31 PM
2008 GMC Sierra - AMSOIL SS 5w30 - 5300~ miles
by Samrsnow - 02/19/20 01:23 PM
Factory Ford filter cut open
by mpgo4th - 02/19/20 01:01 PM
VW coolant G12+ compatable G12++
by raaizin - 02/19/20 12:27 PM
Fun Electrical Gremlins with the Jeep
by Miller88 - 02/19/20 11:59 AM
Checking inner CV joints on fwd
by ram_man - 02/19/20 11:39 AM
AIR FRANCE FLIGHT 296
by 53' Stude - 02/19/20 10:51 AM
Brakes failing randomly
by Avery4 - 02/19/20 10:28 AM
Reliable Brand Washer / Dryer
by diyjake - 02/19/20 10:05 AM
Royal purple oil filters have gone downhill?
by Sprite - 02/19/20 09:25 AM
Meguiar's Ceramic Wax, $13.97 @ Wmart
by wemay - 02/19/20 09:23 AM
2015 Forester - whine/Rough at specific RPM
by MoneyJohn - 02/19/20 09:06 AM
Brake hum when backing up after a rain storm
by vortex - 02/19/20 08:54 AM
TorchHypnosis, Tgibson, GardenStateAudi, Strommen95, Idaholewis
70748 Registered Users
118 registered members (andreigbs, 1978elcamino, 28oz, 750IX, 01rangerxl, 4WD, 14 invisible), 2,382 guests, and 25 spiders.
Topics301,659
Posts5,200,107
Members70,748
Supertech 10W30 Burning up? #2892342 02/02/13 08:51 AM
R
Realtech214 Offline OP
R
I tried supertech 10W30 in my Deere lawn mower and It burned up about 1/4 quart durring 3-4 mows. The John Deere stuff i usualy run in it never burns at all. Is supertech known for burning a bit of oil or is it just not ment for air cooled engines
2015 Silverado Crew Cab 5.3 LT 120,xxx miles
2001 Suburban LT 145,xxx miles
Re: Supertech 10W30 Burning up? [Re: Realtech214] #2892353 02/02/13 09:03 AM
simple_gifts Offline
I would, as a minumum, use an OPE oil for OPE.
2004 Prius; 126K; ALM
2007 Yaris 103K ATM
2006 B2300;137K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Supertech 10W30 Burning up? [Re: Realtech214] #2892354 02/02/13 09:05 AM
B
Barkleymut Offline
B
is the "john deere stuff" multi viscosity?
09 Vue(95K) 2.4 4spd AT -PU 5w30 / 09 Flex(52K)3.5L PU / Moms car 04 Pilot(105K) 5w20 PP + Puro
Re: Supertech 10W30 Burning up? [Re: Realtech214] #2892356 02/02/13 09:05 AM
E
electrolover Offline
E
Air cooled engines run too hot for a 10/30 dino. Not to mention they need more ZDDP than an SN.
Run a syn, hdeo or sae 30
Re: Supertech 10W30 Burning up? [Re: Realtech214] #2892364 02/02/13 09:13 AM
R
R
Deere stuff is 10W30.. just wanted to try the wallyworld stuff, wont use it again though
Re: Supertech 10W30 Burning up? [Re: Realtech214] #2892380 02/02/13 09:25 AM
G
gfh77665 Offline
G
Air cooled engines, especially in the Gulf Coast states, need straight 30wt.
Re: Supertech 10W30 Burning up? [Re: gfh77665] #2892406 02/02/13 09:48 AM
H
heyu Offline
H
+ 1 , Anywhere unless you have below freezing temperatures
72 Chevy Nova beater 355 Run's consistent 12.80s in 1/4 mile (with street tires)
80 Z-28 2nd owner
Re: Supertech 10W30 Burning up? [Re: Realtech214] #2892413 02/02/13 09:56 AM
K
KD0AXS Offline
K
It's probably a 10W-30 HDEO, not an SN/GF5 PCMO like the Supertech.
If it were mine, I'd run Rotella T6 in it.
2013 Jeep Wrangler JKU
2007 F-350 6.0 PSD
2004 Mazdaspeed Miata
Re: Supertech 10W30 Burning up? [Re: Realtech214] #2892421 02/02/13 10:01 AM
L
lexus114 Offline
L
I use 10W-30 VWB in my Cub Cadet 20hp V-twin. Runs nice and smooth on it with no oil burning or problems what so ever.
2018 Nissan Maxima S
Re: Supertech 10W30 Burning up? [Re: Realtech214] #2892439 02/02/13 10:16 AM
G
GMBoy Offline
G
I've been running Mobil 1 10W/30 in all my OPE for atleast 20 years. Every piece of equipment still runs like new and no smoke except for the 2008 Honda powered Husqvarna push mower which is a [censored] engine anyhow.
Re: Supertech 10W30 Burning up? [Re: Realtech214] #2892442 02/02/13 10:20 AM
R
Roadkingnc Offline
R
I use rotella 15w40 in mine
Re: Supertech 10W30 Burning up? [Re: Realtech214] #2892475 02/02/13 11:02 AM
E
E
A motorcycle oil would work well too!
Re: Supertech 10W30 Burning up? [Re: Realtech214] #2892637 02/02/13 01:50 PM
J
Jordan_FX4 Offline
J
Conventional non-ope 10W-30 probably isn't a good choice for your mower as far as protection, at least in the summer time. That being said a decent synthetic should do great at protection, and help your engine run a bit cooler.
I have run Pennzoil Platinum 10W-30 in my Deere 165 Hydro riding mower and the oil level was just barely below the full line after running it all summer. I've also used Shell Rotella 10W-30 with good results if your looking for a good conventional hdeo, and it can be found cheaply pretty much anywhere.
2013 Ford F-150 Pennzoil Platinum 5W20
1966 Ford Mustang PYB 10W30
Re: Supertech 10W30 Burning up? [Re: gfh77665] #2892645 02/02/13 01:56 PM
O
OVERKILL Offline
O
I've used D1 (and TDT) 5w40 as well as M1 0w40 with no consumption issues in my air cooled OPE gear, a straight-weight is not needed. Mind you, I supposed the argument could be made that an expensive synthetic isn't needed either, so that cuts both ways wink
Re: Supertech 10W30 Burning up? [Re: electrolover] #2892650 02/02/13 01:58 PM
Clevy Offline
Good advice.
It's a lawn mower so unless you have some half quarts of syn laying around from an oil change I wouldn't go out and buy any.
Use rotella conventional. 10w-30 or 15w-40 and change every fall
2006 Charger RT
Miles x 2 per oil filter
