Originally Posted By: driver123
No! Do not change the ATF, don't fool with a good thing, it's been my experience, that when these cars are subjected to an ATF change, that's when you start to see slipping. I have worked on a buy here/pay here lot, and I can tell you, when it comes to the sealed GM transmissions, it's better to leave well enough alone. You can, of course go through the tedious routine of checking the fluid level, and topping it off, but trust me, don't worry about changing it.
*Sigh*...I can't wait for this old wive's tale to finally die.
Originally Posted By: RobertISaar
the "fill for life of the unit" mentality is the reason why they don't actually last the life of the rest of the vehicle anyways.
Exactly.
Originally Posted By: fisher83
most of the transmissions that fail from the flushes were probably on their way out in the first place. Lots of people don't even consider servicing their transmission until there is some sort of shifting issue at which point it is probably too late.
Exactly.
Originally Posted By: MolaKule
A marginal tranny is going to fail anyway, no matter what fluid you use.
From the Master.
