Originally Posted By: simple_gifts
Oracle hardware maintenance:
Thomas, I have seen you logged a ticket for a failed hard drive; please upload the logs /var/adm/messages and iostat to the support site;
1 hour later; Thomas I have reviewd the logs and we will dispatch a new disk via courier; Is your address still.....
Yes; Thank you; btw, we have "keep the disk" so I won't be returning the failed drive.
Dell server support:
me: I'd like to log a ticket for a failed drive;
them:How do you know it is failed?
me:The raid controller offlined it and it indicated "failed".
them
id you reseat the drive?
me:No why would we do that when the raid controller said it is bad?
them
id you flash the firmware prior to logging the ticket?
me:No.
them:I need you update the firmware on the RAID controller.
me:Respectfully, this machine has been running 24x7 for 4 years.
them:I need you to load this .exe file so it can report on the status of the disks.
me:It is running Redhat; it doesn't use .exe files
them:Ok, I'm going to send you a program where you can make a bootable USB stick, but the .exe file on it and boot from that.
me
ude, the machine is running production for our customer, the RAID controller said the disk is bad, just send us a replacement disk, thanks.
them:We have a guy in the area tomorrow. is that ok?
me:No, we have 4 hour response; we need the disk today.
them:my metrics are based on customers completing the tasks I have, you'll boot from the USB and run the utility later on?
me: ya, sure dude; i'm on that....
Wow deja vue! That brings back the first time I called Dell back in 01.. what a experience. With HP it was more like "Ok what's your issue".. Fill in short explanation with bad part and part number.. "Ok you'll have one in 3 days". Hence I've always owned HP's except going to Apple now. Probably not the same now but worked for me!
