Originally Posted By: Oil Changer
I can not prove if it was the fluid or not but the fluid is the only variable.
The fluid was the only variable? What about the miles you were putting on the vehicle while the fluid was in there? Do you think they might have had something to do with it?
It is very simplistic thinking to automatically draw a rigid correlation between an event and the last "thing" that preceeded it. If we are going to follow that logic, how do we know that maybe the last time you changed the fluid you didn't use your Lucky Wrench, or Lucky Drain Pan, or whatever? Did a black cat walk near the vehicle while you were changing the fluid? These possibilities seem every bit as likely.....
