Hi,
So after years of working on personal vehicles (import and domestic), I'm wondering if you guys can give some tips/info on drain plug gaskets/crush washers. On the Fords I've worked on, the oil drain plug never seems to have a gasket. My Toyota and Hyundai (and previous Nissan) use aluminum crush washers or fiber gaskets.
At the parts store I've come across many different types of crush washers/gaskets. The most common ones I see are the copper/aluminum, rubber, and fiber based gaskets. Is there a rule of thumb on picking which one to use and if certain types are interchangeable? It would be a lot more conveniate if I could just buy a bulk box of assorted gaskets on eBay to use on everything rather than having to make a trip to the stealership everytime to get the OEM one.
