I've had good and bad luck with wet cells WRT corrosion, but all of my previous cars were either old or cheap, so the added rust and corrosion didn't make much of a difference, especially ince I kept the area clean. So, while I was interested in AGM batteries, it never made financial sense to me.
That all changed after the OEM Subaru battery began leaking and causing early corrosion issues. Subaru checked the charging system and battery and said both were good, so they wouldn't replace it due to top post corrosion. The battery hold-down was rusting, and the paint beneath and around the battery was beginning to bubble. This is with routine cleaning of the battery.
I put out the money for a nice AGM battery from Sears and couldn't be happier. I haven't noticed any corrosion and I never have to check it or clean it. The extra reserve and respectable CCA were nice benefits, too. We'll see how well it lasts, but the yellow top that came with one of my old cars has lasted for a long time, even after being recharged from fully dead maybe 4 times.
I'm still on the fence about whether or not to buy one for my wife's Civic, when it comes time to replace her's (OEM Honda,) but another AGM might be in the cards. She drives a lot (a lot of highway on top of that,) which lends itself for a long-living wet cell; however, she also spends time in the city and tends to aim for every pot hole in the road, which make an AGM the better choice in the long run.
