Why do you feel you need a cleaner? Unless you see sludge in the radiator I would just do a drain and fill of the radiator once or twice.
With the modern coolant I do not think a cleaner is needed very often.
If there is sludge in the overflow, I would remove it, fill with hot water and Dawn dish washing detergent and shake.
