Oil Change Special @ Firestone
by Mad_Hatter - 09/19/19 01:05 PM
TiO2 as a grease additive -solid lubricant?
by berlyn - 09/19/19 12:46 PM
Why is Mobil Super so expensive?
by Mad_Hatter - 09/19/19 12:04 PM
Dodge Ram 2500 Transfer Case leaking
by diyjake - 09/19/19 11:24 AM
Have you seen anything like this?
by JDubyah - 09/19/19 11:06 AM
Valvoline Premium blue, Ram 3500
by TOLSON - 09/19/19 10:55 AM
Little engine, big filter
by brages - 09/19/19 10:54 AM
Thoughts on adding AC/Heat to attached garage.
by FADEC - 09/19/19 10:31 AM
What to do with old cores?
by Brybo86 - 09/19/19 09:49 AM
Which additive for best MPG?
by cwilliamsws6 - 09/19/19 08:25 AM
Clock radio lights failing on '08 Honda CR-V
by dpaldino - 09/19/19 08:14 AM
16 F150 3.5EB ~8K VPB 15W40
by BeerCan - 09/19/19 07:55 AM
Old skool carburetor rebuilding.
by Chris142 - 09/19/19 07:50 AM
Construction - Vintage Warning
by MasterSolenoid - 09/19/19 06:55 AM
Toro 12-38
by supton - 09/19/19 06:36 AM
EV tuktuk batteries
by Superflan - 09/19/19 02:09 AM
Car engine issues
by Espada - 09/19/19 01:12 AM
2002 chevy tahoe 5.3 oil selection
by Zahndkile - 09/19/19 12:20 AM
Considering Solar
by mbacfp - 09/18/19 11:16 PM
ProBest, Zolton, 1Favoritoil, IanNV, JDubyah
69330 Registered Users
107 registered members (50jeffrey, 1978elcamino, 330indy, 87sammy, 928, 53' Stude, 7 invisible), 2,206 guests, and 26 spiders.
Topics294,779
Posts5,066,469
Members69,330
Most Online3,532
Jul 30th, 2019
Lucas Oil Stabilizer?? #2840129 12/19/12 12:38 AM
U
ukmastermind Offline OP
U
What the heck is that stuff?
Guy @ auto parts store was really pushing it hard. The bottle makes numerous claims (e.g. "pure petroleum," "keep that engine alive," "Increa. Compression," etc)
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840148 12/19/12 01:14 AM
R
randomhero439 Offline
R
Why do you need it?
'08 BMW E92 335xi 6MT, Castrol 0w-40, daily
'10 Mercedes GLK: M1 0w-40, wife's car
'00 S2000: M1 0w-40, summer daily & track car
'08 Corvette Z06: M1EP 5w-30, summer daily & track toy
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840149 12/19/12 01:16 AM
F
fauxchemist Offline
F
Lucas oil Stabilizer is junk. Way to thick for any application. Why is he pushing it on you? Burning oil?
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840150 12/19/12 01:22 AM
R
R
Burning too much oil? If your using synthetic, up the oil grade. Still burning, switch to conventional using your normal oil grade. If using conventional, switch to a high-mileage oil. If that doesnt work, use a conventional high-mileage with a higher grade.
Synthetic
5w-30 --> 5w-40
5w-20 --> 5w-30
Conventional
5w-30 --> 10w-40
5w-20 --> 5w-30
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840169 12/19/12 02:16 AM
B
BobsArmory Offline
B
I have seen them push Lucas products at different stores in my area. The pitch I get reminds me of when I worked at MC Sporting Goods when I was just out of high school. I could sell you any fishing pole in the store but if I got you to buy a Shakespeare Ugly Stick fishing pole I got an extra $1.50 added to my pay check.
Keeping the forces of evil at bay
2016 Chevy Malibu LT 1.5 Liter Turbo
2017 Chevy Equinox LT 2.4 Liter
2007 Pontiac Grand Prix 3800 Series III
Re: Lucas Oil Stabilizer?? [Re: randomhero439] #2840176 12/19/12 02:45 AM
skyship Offline
Synthetic
5w-30 --> 5w-40
5w-20 --> 5w-30
Conventional
5w-30 --> 10w-40
5w-20 --> 5w-30
Very good advice, oil thickners are only good for one thing and that is selling badly worn rattly engines. An engine run on thick oil will sound good when warmed up, but suffer horrific cold start wear, because you might well change an 0/40 into a 20/60, which is not good news in winter. Before buying a used car from a dealer in the old days, I used to check their rubbish bins for empty STP cans and not go near a car that had already been warmed up, just in case it was a cold start piston slapper.
Don't be tempted by the snake oil salesmen, just find a better oil.
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840215 12/19/12 05:52 AM
B
bigjl Offline
B
When I was younger is used these kind of products. STP or Lucas.
Probably caused more harm than good.
16 S350d LWB 25k Mobil Super 3000 XE 5w30
17 Smart ForFour Auto 6.5k Mobil 1 0w40 FS
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840228 12/19/12 06:41 AM
J
jorton Offline
J
It's for diesel engines. Thinner Lucas full synthetic oil stabilizer is for gasoline engines. They are for noisy worn out engines.
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840248 12/19/12 07:43 AM
G
GearheadTool Offline
G
Lucas... is a straight 80-weight Group 1 "oil." It is thick as [censored]. It SAYS it has those benefits.. Now, I have put it in engines that people believe like thicker oil (there are some that do) and it SEEMS to help.. it is basically an oil thickener, and it is supposed to fill in things in cylinders, etc. and "stick" to things, like a Group V (5) oil would.
Many say it does more harm than good.. However, when I added it to engines, I *think* it made it run smoother..
It is not until you get very, very in depth to motor oil application that you begin to question what, if any, "benefit" it has.
In an older, worn, beat-up engine, it thickens the oil, and therefore makes it run better.
If added to older oil, (perhaps sheared?) - It thickens it back up.
Whether or not thicker oil is better, is the issue.
And the sales guy was tasked with seeing if he could "move" some of it.. I actually avoid parts stores now.. I got sick of the LIES. And the pressure. (I come in to look, browse, and buy what I need, if it is good and priced right. 9 times out of 10, it isn't.. so, I shop online.) 2cents
Re: Lucas Oil Stabilizer?? [Re: GearheadTool] #2840265 12/19/12 08:09 AM
skyship Offline
Don't confuse sound with what might be good for an engine. If you thicken up an oil you will slow down the flow and in particular starve the bearings of oil during a cold start. Most engines that fail in a big way sound just fine before something terminal siezes or brakes in a big way.
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840342 12/19/12 09:33 AM
A
ARCOgraphite Offline
A
Garbage.
2019 VW Jetta S 6MT OCI#1 5885mi-Castrol Edge Prof? VW508+VW Service Filter; '17 Subaru Crosstrek CVT OC#7 52665mi-Castrol GTX Magnatec 5W20 + SOA Filter
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840465 12/19/12 11:30 AM
G
Gabe Offline
G
Yea, I ran it.
I was shocked at the amount of foam-type-stuff that it produced. I initially thought that I had a head gasket leaking - it was that bad.
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840511 12/19/12 12:13 PM
G
gomes512 Offline
G
Well they got it right with "Pure Petroleum". As GearheadTool stated it's just a Group 1 brightstock without any additives. You'd be better off buying a quart of racing straight 60 or 70 weight, at least it'd have some AW additives.
Re: Lucas Oil Stabilizer?? [Re: Gabe] #2840590 12/19/12 01:11 PM
G
G
Originally Posted By: Gabe
Yea, I ran it.
Soap bubbles come out of it when squeezed when poured.
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2841705 12/20/12 10:16 AM
E
electrolover Offline
E
Lucas is a good product for the right car......like an old oil burner or something. It does its job which is thicken the oil and add detergents. Some guys around here like running it in dirt trackers and the local engine shop says the bearing look good after running it for a season..........but so do the bearings in engines that run 20/50. Its not for a newer car in myy opinion
