2019 Jeep Wrangler Unlimited Rental
by 2015_PSD. 07/21/19 10:33 AM
Galvanic corrosion
by LeakySeals. 07/21/19 10:20 AM
Ford EcoBoost Oil Catch Can?
by JeffKeryk. 07/21/19 10:17 AM
Hybrid-Keep or Trade
by Spector. 07/21/19 10:05 AM
STP S 4967 NEW FILTER CUT OPEN
by 53' Stude. 07/21/19 09:03 AM
Is my mower battery going to die one day?
by motor_oil_madman. 07/21/19 08:26 AM
Repurposing Sears and other retail sites
by Kira. 07/21/19 07:34 AM
Amsoil XL 5W30 1.5LT
by ARB1977. 07/21/19 07:17 AM
HF: Bauer Grinder Teardown/Analysis
by RayCJ. 07/21/19 05:55 AM
P21S Windshield Wash Booster
by Duffyjr. 07/21/19 05:25 AM
Transmission Swap
by Ponchinizo. 07/20/19 11:41 PM
Ecogard S4477
by Steiny. 07/20/19 11:25 PM
Fuel Tanker Driver Here
by GoldDot40. 07/20/19 10:25 PM
Overfilled diff?
by HoosierJeeper. 07/20/19 10:02 PM
Brake Surge - Lexus
by MaximaGuy. 07/20/19 09:55 PM
Oil Rec for Street Driven & Track Usage
by randomhero439. 07/20/19 09:46 PM
Paint correction lighting setup for white paint
by Reddy45. 07/20/19 09:07 PM
Cannot pull credit report for wife
by Klutch9. 07/20/19 08:24 PM
Toyota 2AZ - FE!??
by miden851. 07/20/19 08:23 PM
AMHKCMO, vanenk, grikor, Mikelima, mannydingo
68722 Registered Users
81 registered members (AdditiveOCD, 2015_PSD, 4WD, 53' Stude, 1foxracing, 87sammy, 11 invisible), 2,227 guests, and 29 spiders.
Topics292,185
Posts5,018,364
Members68,722
Most Online2,967
Mar 10th, 2019
Lucas Oil Stabilizer?? #2840129
12/19/12 12:38 AM
12/19/12 12:38 AM
Los Angeles, CA
ukmastermind Offline OP
Los Angeles, CA
What the heck is that stuff?
Guy @ auto parts store was really pushing it hard. The bottle makes numerous claims (e.g. "pure petroleum," "keep that engine alive," "Increa. Compression," etc)
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840148
12/19/12 01:14 AM
12/19/12 01:14 AM
ohio
randomhero439 Offline
ohio
Why do you need it?
'08 BMW E92 335xi 6MT, Castrol 0w-40, daily
'10 Mercedes GLK: M1 0w-40, wife's car
'00 S2000: M1 0w-40, summer daily & track car
'08 Corvette Z06: M1EP 5w-30, summer daily & track toy
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840149
12/19/12 01:16 AM
12/19/12 01:16 AM
Harrison AR
fauxchemist Offline
fauxchemist  Offline
Harrison AR
Lucas oil Stabilizer is junk. Way to thick for any application. Why is he pushing it on you? Burning oil?
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840150
12/19/12 01:22 AM
12/19/12 01:22 AM
ohio
ohio
Burning too much oil? If your using synthetic, up the oil grade. Still burning, switch to conventional using your normal oil grade. If using conventional, switch to a high-mileage oil. If that doesnt work, use a conventional high-mileage with a higher grade.
Synthetic
5w-30 --> 5w-40
5w-20 --> 5w-30
Conventional
5w-30 --> 10w-40
5w-20 --> 5w-30
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840169
12/19/12 02:16 AM
12/19/12 02:16 AM
Michigan
BobsArmory Offline
BobsArmory  Offline
Michigan
I have seen them push Lucas products at different stores in my area. The pitch I get reminds me of when I worked at MC Sporting Goods when I was just out of high school. I could sell you any fishing pole in the store but if I got you to buy a Shakespeare Ugly Stick fishing pole I got an extra $1.50 added to my pay check.
Keeping the forces of evil at bay
2016 Chevy Malibu LT 1.5 Liter Turbo
2017 Chevy Equinox LT 2.4 Liter
2007 Pontiac Grand Prix 3800 Series III
Re: Lucas Oil Stabilizer?? [Re: randomhero439] #2840176
12/19/12 02:45 AM
12/19/12 02:45 AM
Tettnang, Baden-Wurttemberg, G...
skyship Offline
skyship  Offline
Synthetic
5w-30 --> 5w-40
5w-20 --> 5w-30
Conventional
5w-30 --> 10w-40
5w-20 --> 5w-30
Very good advice, oil thickners are only good for one thing and that is selling badly worn rattly engines. An engine run on thick oil will sound good when warmed up, but suffer horrific cold start wear, because you might well change an 0/40 into a 20/60, which is not good news in winter. Before buying a used car from a dealer in the old days, I used to check their rubbish bins for empty STP cans and not go near a car that had already been warmed up, just in case it was a cold start piston slapper.
Don't be tempted by the snake oil salesmen, just find a better oil.
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840215
12/19/12 05:52 AM
12/19/12 05:52 AM
London, England
bigjl Offline
bigjl  Offline
London, England
When I was younger is used these kind of products. STP or Lucas.
Probably caused more harm than good.
16 S350d LWB 25k Mobil Super 3000 XE 5w30
17 Smart ForFour Auto 6.5k Mobil 1 0w40 FS
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840228
12/19/12 06:41 AM
12/19/12 06:41 AM
San Antonio, TX
jorton Offline
jorton  Offline
San Antonio, TX
It's for diesel engines. Thinner Lucas full synthetic oil stabilizer is for gasoline engines. They are for noisy worn out engines.
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840248
12/19/12 07:43 AM
12/19/12 07:43 AM
Boston, MA
GearheadTool Offline
Boston, MA
Lucas... is a straight 80-weight Group 1 "oil." It is thick as [censored]. It SAYS it has those benefits.. Now, I have put it in engines that people believe like thicker oil (there are some that do) and it SEEMS to help.. it is basically an oil thickener, and it is supposed to fill in things in cylinders, etc. and "stick" to things, like a Group V (5) oil would.
Many say it does more harm than good.. However, when I added it to engines, I *think* it made it run smoother..
It is not until you get very, very in depth to motor oil application that you begin to question what, if any, "benefit" it has.
In an older, worn, beat-up engine, it thickens the oil, and therefore makes it run better.
If added to older oil, (perhaps sheared?) - It thickens it back up.
Whether or not thicker oil is better, is the issue.
And the sales guy was tasked with seeing if he could "move" some of it.. I actually avoid parts stores now.. I got sick of the LIES. And the pressure. (I come in to look, browse, and buy what I need, if it is good and priced right. 9 times out of 10, it isn't.. so, I shop online.) 2cents
"Listen, Walter, just because you shot Jesse James... don't make you Jesse James."
2000 Volvo V70 XC AWD - 138k mi. - SOLD! 2/16/03, Redline 0W-20
Re: Lucas Oil Stabilizer?? [Re: GearheadTool] #2840265
12/19/12 08:09 AM
12/19/12 08:09 AM
skyship Offline
skyship  Offline
Don't confuse sound with what might be good for an engine. If you thicken up an oil you will slow down the flow and in particular starve the bearings of oil during a cold start. Most engines that fail in a big way sound just fine before something terminal siezes or brakes in a big way.
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840342
12/19/12 09:33 AM
12/19/12 09:33 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Garbage.
2019 VW Jetta S 6MT OCI#0 5033mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#7 52665mi-Castrol GTX Magnatec 5W20 + SOA Filter
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840465
12/19/12 11:30 AM
12/19/12 11:30 AM
Indiana
Gabe Offline
Gabe  Offline
Indiana
Yea, I ran it.
I was shocked at the amount of foam-type-stuff that it produced. I initially thought that I had a head gasket leaking - it was that bad.
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2840511
12/19/12 12:13 PM
12/19/12 12:13 PM
Chicago, IL
gomes512 Offline
gomes512  Offline
Chicago, IL
Well they got it right with "Pure Petroleum". As GearheadTool stated it's just a Group 1 brightstock without any additives. You'd be better off buying a quart of racing straight 60 or 70 weight, at least it'd have some AW additives.
Re: Lucas Oil Stabilizer?? [Re: Gabe] #2840590
12/19/12 01:11 PM
12/19/12 01:11 PM
Boston, MA
Boston, MA
Originally Posted By: Gabe
Yea, I ran it.
Soap bubbles come out of it when squeezed when poured.
Re: Lucas Oil Stabilizer?? [Re: ukmastermind] #2841705
12/20/12 10:16 AM
12/20/12 10:16 AM
TEXAS
electrolover Offline
TEXAS
Lucas is a good product for the right car......like an old oil burner or something. It does its job which is thicken the oil and add detergents. Some guys around here like running it in dirt trackers and the local engine shop says the bearing look good after running it for a season..........but so do the bearings in engines that run 20/50. Its not for a newer car in myy opinion
2004 F150 5.4 160k-Castrol TXT 5/40, Distance+ 3410-KREEN
2004 Explorer 4.0 130k-PU 5w30, Distance+ 3410
