Originally Posted By: SlipperyPete
Originally Posted By: Ibrahim
WIX XP: 51334XP
Napa Platinum: PFL 41334
Amsoil Ea0: Ea15K20
Donaldson: P550162
I appreciate all the responses.
The filters listed above, with the exception of the Amsoil filter, list a bypass setting that is too low. The Amsoil filter doesn't list their bypass psi at all that I can find.
The Purolator Synthetic doesn't list a Subaru part number, at least not on the Advance Auto web site.
I guess I'll see about getting an oem filter, or look into going 10k with a Bosch Premium or P1.
Thanks
My guess is that they'll use the same exact number.
Here are the Purolator part numbers applicable to a 2001 Subaru Outback with the EJ25:
Classic: L14460
PureONE: PL14460
based off of that pattern, the Purolator Synthetic Filter part number is likely to be:
PSL14460
..as the box in the Purloator Synthetic Filter page lists the first three letters as "PSL":
http://www.purolatorautofilters.net/products/oil_filters/Pages/SyntheticOilFilters.aspx
I have much confidence in Purolator and their filters designed specifically for Subaru engines, since they did once make the OEM filters for Subaru. Of course, the leaking filters issue is no more so never any worries running a Purolator on a Subaru, since they have the right bypass valve pressure setting
