Is DEXRON LS 75W-90 synthetic ?
UNION CITY, TN
Does anyone know for sure (one way or another) if DEXRON LS 75W-90 Gear Lube is synthetic, semi-syn or dino base gear lube ? The GM / AC-DELCO bottle it comes in does not say it is or isn't , but it does say it is on their 75W-90 Synthetic Gear Lube. Just need to know for 100% certainty.
Dexron is normally reserved for the GM auto trans fluid.
Normally if something is a partial syn or full syn fluid any bottle will tout it as such. I would think it's just a non syn is my guess.
If it is GM part number 88862624 (DEXRON LS GEAR OIL 75W-90) it is a Limited Slip Differential lube made by PetroCanada and has GroupII and III base oils.
That is the part# , so it is not synthetic ?
I emailed them and got this :
Hi Brad,
Thank you for submitting your question to the Petro-Canada Lubricants website. Dexron LS Gear Oil 75W-90 is a synthetic extreme pressure automotive axle lubricant with limited slip top treat package. It is formulated for GM Axle Service Fill applications.
I hope that helps.
Regards,
Michael Kaufman
Technical Services Advisor
Petro-Canada Lubricants Inc.
Tel 1-888-877-6522
[email protected]
http://lubricants.petro-canada.ca/
Suncor Energy is the proud owner of Petro-Canada
I asked for some clarification and got this email reply :
Hi Brad,
Yes. Dexron LS Gear Oil 75W-90 is fully synthetic.
Please do not hesitate to contact me if you have any further questions.
Regards,
Michael Kaufman
Tel 1-888-877-6522
