Originally Posted By: skyship
Originally Posted By: JoshV5
Hi, Guys,
I was wondering is it OK for me to use 0W-20 for winter about 3 Month and 5W-20 for the rest of the year?
I drive a 07 Honda Accord 2.4L with 80,000+ miles on it, I’m an easy driver, majorly drive in city.
Here in the mid-west winter can be really cold, typically below and around 32 degree. But in the summer it will even go above 100 degree sometimes.
So,
Is it good for my car to switch around between 0W-20 and 5W-20? Or I should keep using 5W-20?
Is it necessary to use those “High mileage/Extended Performance” oils? My local shops always tell me to use their “High mileage” version of their 5W-20.
Thank you guys very much!
The 0W/20 is slightly better in cold start terms if you have very cold winters, so most folks in Canada like 0W something engine oils.
High mileage oils are not the same as EP or Longlife oils and they are only of use if you have oil leaks or sludge problems etc. They swell the seals, which is not good news if there is nothing wrong to start with.
Do some research into the possibility that a 5/30 oil might be better in engine wear terms. The best German engine oil company (Liqui Moly) does not make 0 or 5/20 oils at present, because they have not been proven to reduce engine wear factors and in most tests of non hybrid engines, the opposite was true. For a cold climate with no pre heater I suspect the best oil might well be a 5/30, but always do your own research.
If you still have an extended power train warranty, do check what it says, as some refer to a list of approved oils, although in most countries the manufacturer has to prove use of the wrong oil caused the failure. It does depend on what you signed, as some documents constitute a contract between you are the dealer and even force you to use the dealer for engine related servicing.
Figuring out the best OCI and the type of oil filter, along with driver style make much more difference than a one grade difference in the oil.
Minus 35C is the normal limit for a 5W oil, so the 0W oil might be best if you don't use a pre heater. Pre-heaters make a real difference in cold start terms and a simple sump heater does not cost too much.
If most of your cars useage involves getting stuck in traffic, then reduce the normal OCI (By half in a bad case) if no severe service figure is quoted. A UOA can help figure out the correct OCI.
I just had a look at the LM oil finder site in Germany and assuming this is the K24Z3 engine, it only lists 0 and 5/30 oils.
The German experts think what is going on with the recommended oil weights is rather silly both in engine wear, oil consumption and oil leak rate terms.
Some new hybrid engines were designed for lghter oils, BUT most new engines use the same basic block as previous models where the best oil was listed as 0 or 5/30 and the manufacturers just changed the paperwork in a crazy attempt to improve fuel economy figures. The difference in cost terms between the fuel saving of a 20 and a 30 grade is often less than the cost of the top up oil.
For the benefit of the OP, the LM listed OCI for severe service is 10K km, so if you do very little highway driving a 5K mile oil only change followed by a 10K mile full service might be good, but without a UOA it's difficult to know the best figure.
Be careful, I got into some very hot water, as well as a few others for going down this path. LOL
