How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Sludge and Facebook's infinite wisdom
by RDY4WAR. 03/24/19 02:05 PM
Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
Jcountry, CMichael, dude59, Petrolhead, stp
67608 Registered Users
109 registered members (A1O, 2015_PSD, Aichiguy, AdditiveOCD, 53' Stude, 15 invisible), 2,143 guests, and 65 spiders.
Topics286,352
Posts4,906,952
Members67,608
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
Eneos Sustina 0w50 -- VOA #2816079
11/27/12 04:29 PM
11/27/12 04:29 PM
Plano, TX
dparm Offline OP
dparm  Offline OP
Plano, TX
I had the KV @ 40 test done, too, which is not a standard test.
2017 Chevrolet Corvette Grand Sport
Re: Eneos Sustina 0w50 -- VOA [Re: dparm] #2816115
11/27/12 04:54 PM
11/27/12 04:54 PM
Massachusetts
deven Offline
deven  Offline
Massachusetts
From the numbers alone point of view...this oil leaves a lot to be desired. TBN of 7.4 is quite low in my opinion be it an ester oil or not.
Proud user of ROYAL PURPLE products!
2016 Acura RLX Sports Hybrid(Royal Purple HPS 5w30 + M1-110 oil filter)
KEEP IT SIMPLE STUPID. IT'S ONLY OIL
Re: Eneos Sustina 0w50 -- VOA [Re: deven] #2816144
11/27/12 05:21 PM
11/27/12 05:21 PM
Plano, TX
dparm Offline OP
dparm  Offline OP
Plano, TX
Correct, but consider that it has a VI of about 200. Supposedly they're using next-gen basestocks.
Re: Eneos Sustina 0w50 -- VOA [Re: dparm] #2816160
11/27/12 05:40 PM
11/27/12 05:40 PM
Massachusetts
deven Offline
deven  Offline
Massachusetts
Yes, I never go by the numbers alone. Numbers are numbers but the proof is always in the pudding itself.
Re: Eneos Sustina 0w50 -- VOA [Re: dparm] #2816165
11/27/12 05:48 PM
11/27/12 05:48 PM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
That TBN is A LOT lower than the 11.2 quoted to me by Sarah Park from their tech dept.
I wonder who to believe??
(The calcium is decent, so maybe Blackstone? {is this who you used??} got it wrong?)
The moly is slightly higher than what I expected, and the boron is slightly lower than I was hoping for. frown
But if it is as shear stable as we suspect, and with that high VI, it is still great stuff, and fully blendable with their 0W-20 to get a perfect weight, VERY high VI brew. wink
2016 Ford Fiesta ST 14K miles
Ravenol DXG 5W-30
Amsoil Ea15K51 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Eneos Sustina 0w50 -- VOA [Re: dparm] #2816172
11/27/12 05:58 PM
11/27/12 05:58 PM
Plano, TX
dparm Offline OP
dparm  Offline OP
Plano, TX
Possible they are using additives Blackstone doesn't test for, like antimony.
Re: Eneos Sustina 0w50 -- VOA [Re: dparm] #2816186
11/27/12 06:09 PM
11/27/12 06:09 PM
Burlington, Ontario, Canada
CATERHAM Offline
CATERHAM  Offline
dparm, thanks for posting this.
Blackstone's KV100 value of only 15.5cSt is at lot lower (10.4%) than the Sustina PDS figure of 17.29cSt which drops the oil into the 40wt range. The lower KV100 figure results in a VI of only 172 so something is not right here.
It's worth noting that Blackstone VOA of the Sustina 0W-20 had a KV100 of 7.60cSt vs the PDS spec' of 7.94cSt; 4.3% lower. And when I first ran the oil I did notice an oil pressure drop somewhat in the first few miles and then stabilize. So just the process of heating the oil to test could result in some permanent shear.
Anyway, I'd ask Blackstone to test the 0W-50 KV100 spec' again; the difference is way too big which the VI doesn't support.
As for the other elemental values, the Phos, Moly and Boron figure are about 10% higher than for their 0W-20 oil, VOA is below:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2702321&page=2
I was hoping that the Phos' level would have been higher.
On balance, my opinion on this oil is dependant on resolving the KV100 spec' difference. I'm hoping the Blackstone figure is incorrect, but if they stand by it, I would be writing Sustina for an explanation.
-'74 Lotus Europa, 5W-50 & VSOT
-'96 BMW 328i, 50/50 TGMO 0W-20/M1 0W-40
-'94 Caterham 7, FUCHS 0W-20
-'18 Tesla Model 3 - FF diff' oil
Re: Eneos Sustina 0w50 -- VOA [Re: dparm] #2816197
11/27/12 06:25 PM
11/27/12 06:25 PM
Plano, TX
dparm Offline OP
dparm  Offline OP
Plano, TX
Good point. I've sent Blackstone a note to request this be re-run.
If the Blackstone number holds true, I would actually be a bit concerned about the 0w50/0w20 mix I made (5:2 ratio) -- might be borderline too thin for my motor.
Re: Eneos Sustina 0w50 -- VOA [Re: dparm] #2816209
11/27/12 06:34 PM
11/27/12 06:34 PM
CATERHAM Offline
CATERHAM  Offline
Well lets not jump to any conclusions yet.
But if B'Stone is right, this simply isn't a 50wt oil and Sustina has some serious explaining to do.
Re: Eneos Sustina 0w50 -- VOA [Re: dparm] #2816210
11/27/12 06:35 PM
11/27/12 06:35 PM
Plano, TX
dparm Offline OP
dparm  Offline OP
Plano, TX
Hopefully Eneos doesn't spout some "manufacturing variances" [censored]....
Re: Eneos Sustina 0w50 -- VOA [Re: dparm] #2816214
11/27/12 06:43 PM
11/27/12 06:43 PM
CATERHAM Offline
CATERHAM  Offline
We're talking a full grade difference so there can be no dancing around that.
Lets hope B'Stone is wrong or the $hit will fly.
Re: Eneos Sustina 0w50 -- VOA [Re: dparm] #2816801
11/28/12 12:12 PM
11/28/12 12:12 PM
Plano, TX
dparm Offline OP
dparm  Offline OP
Plano, TX
Blackstone sez:
Hi, Dan. We re-ran that viscosity test at 100C (twice, just to be sure), and came back with a very similar reading of 15.913 cSt, or 81.6 SUS. This is slightly higher than the test we ran yesterday, but still not quite in the SAE 50-weight range.
A slightly lower viscosity isn't all that unusual with multi-weight oils, however. We base our "should be" values on the observed ranges of the oils we've tested, and we find that oils with a larger gap between the winter-weight and the SAE-weight will tend to have a slightly lower viscosity range than a multi-weight with a smaller difference between the two numbers, or a straight-weight oil of the same viscosity.
For example, a 0W/50, 20W/50, and straight SAE 50-weight oil should theoretically all have the same viscosity range at 100C, but that's never been the case in any of the oils we've tested. The straight 50-weight oil should fall within the proper range for SAE 50 oil, but we expect the 20W/50 oil to read a bit lighter, and the 0W/50 oil to read even lighter still. We've tested samples from many different brands of 0W/50 oil, both virgin and used, and most fall at the light end of the 50-weight range or slightly lower.
Hope that helps. Let me know if there's anything else we can do for you. Thanks!
Re: Eneos Sustina 0w50 -- VOA [Re: dparm] #2816821
11/28/12 12:38 PM
11/28/12 12:38 PM
Massachusetts
deven Offline
deven  Offline
Massachusetts
^^So how do you feel about mixing 0w50 and 0w20 now?
Re: Eneos Sustina 0w50 -- VOA [Re: deven] #2816823
11/28/12 12:40 PM
11/28/12 12:40 PM
Plano, TX
dparm Offline OP
dparm  Offline OP
Plano, TX
A bit nervous, though I suspect it's still fine. The motor sheared Syntec 5w40 out of grade in only 5k, so I plan to sample at 2.5k to see how this is holding up.
Re: Eneos Sustina 0w50 -- VOA [Re: dparm] #2816828
11/28/12 12:45 PM
11/28/12 12:45 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
dparm - Could be the oil not the engine. Only one way to find out.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Page 1 of 4 1 2 3 4
