I've done it pretty much the same as chevorfreak, and had good results on newer EFI cars. I also filled an old Windex bottle with hot water and sprayed that into Carburetors many years ago. Seemed like a safer way to do it. I got the idle speed up to around 2000 rpm and sprayed it rapidly into the engine pausing about every 15 seconds. Usually did about 2 bottles.
Does anyone know if doing this into the TB, or air intake hose on a newer EFI engine will mess up any sensors going into it as a mist? Doing it as a mist will pretty much eliminate locking up the engine.
Thanks,
Frank D
Thanks,
Frank D
