My Corolla is approachng 20k miles now and I am looking for some help in setting up a maintanence schedule on items that I can do myself. I plan on keeping this car for a long time. So far I have had the oil changed and tires rotated at 5k, 10k, and 15k miles at the dealer (only because it was free). I plan on sticking with 5k oil changes and tire rotations for the life of this vehicle. I also kind of wanted to lump some items together at the same intervals to make things easier on me. I average driving ~12k miles a year.
These are some of the intervals I was thinking:
Oil/filter change and rotate tires - every 5k
Change air filter ( & cabin filter) - every 20k
Drain / fill transmission fluid - every 20k
Brakes - as needed, flush all brake lines when brake pads are changed.
Replace PCV valve - every 50k
Drain/fill coolant - every 50k
No power steering fluid to change
Spark plugs - ?
Adjust rear drum brakes - ?
Anything else to add to my list? This car doesn't have any grease points, correct? I was thinking cleaning the MAF sensor should be added, but unsure of how often to clean it. Any other thoughts are appreciated!
Spark plugs - ?
