I've got 2 extra deep cycle batteries, at 62 lbs each.
I've significantly upgraded the charging circuit with 2 awg cable
I've reduced the size of the Alternator pulley. It is rated at 130 amps.
I have a digital ammeter that has shown 120 amps with a cold alternator and 3500 engine rpm, but back down at idle speeds the amps taper to 62 when still cold and mid to high 20's when hot.
Once your vehicle's voltage regulator approaches its max setpoint, the alternator only produces enough amperage to hold that voltage. Once this threshold is reached, a higher rated alternator will do nothing unless you are also running 70 amps of driving lights.
On my Vehicle, this can be as low as 7 amps to hold 14.5 volts, even with depleted deep cycle batteries. If I shut the engine off at this point, and hook up a grid powered battery charger, the batteries will accept 30+ amps.
Alternator charging just does not work that well, Despite what many people think. It takes time to charge a battery, especially the last 20%. No way around it.
