Originally Posted By: Carnoobie
Im gonna try to clean my posts tommorow, do I put vaseline around the battery terminals before i reconnect the cables?
That's OK. You can put the grease on either way, before or after. I prefer to do it before so as to exclude oxygen from the entire surface. The terminal has little ribs that dig into the post. These cut through the grease, so no worries about accidentally insulating the post.
Also, which should i use? I have sandpaper, baking soda, and toothbrush on me. Dont have wire brush.
Sandpaper is fine. I prefer emery cloth, since it doesn't rip the way sandpaper does. Don't forget to do the inside of the terminal loop.
If you have corrosion, make a really thick paste of water and baking soda. The consistency of the mix will be like toothpaste. Remove the terminal from the post, smear the paste all over the post, terminal, and wiring, and wait for it to bubble and turn green, maybe 15 minutes. Wipe off and repeat until the terminal, post, and wiring are all squeaky clean.
However, if you have corrosion, you need to replace your battery, otherwise the corrosion will come right back.
