CV Joint Leaking Grease
by 92saturnsl2 - 08/22/19 10:20 PM
Craftsman 6 pc. Screwdriver Set $12.14
by Warstud - 08/22/19 09:32 PM
Got My ATF Replaced.
by Mr_Luke - 08/22/19 09:20 PM
Wht do people with labor intensive jobs lay on their back?
by motor_oil_madman - 08/22/19 09:14 PM
Date code 5 Q Chevron location?
by Onetor - 08/22/19 08:06 PM
Confused, what oil to use?
by BelAir - 08/22/19 08:00 PM
2015 KIA optima turbo Coolant Flush
by Grambo - 08/22/19 07:52 PM
Motul 300V -- oops
by xr650boy - 08/22/19 06:35 PM
Evolution of Garbage Trucks...joke thread
by GumbyJarvis - 08/22/19 05:57 PM
What is this Oil's Application?
by MolaKule - 08/22/19 05:19 PM
Ford 2.5L Engine and 6F35 Transmission
by drh214 - 08/22/19 04:57 PM
Fram XG7317 vs XG3593A
by gamefoo21 - 08/22/19 03:59 PM
Carquest premium 85334
by SlavaB - 08/22/19 03:47 PM
Oil for a Ford 2.8 L Cologne V6
by ford4wd08 - 08/22/19 03:46 PM
Good Question?🤔
by Mad_Hatter - 08/22/19 01:40 PM
Autozone misinformation?
by NavyVet88 - 08/22/19 11:23 AM
Did I mess up getting a civic that sat?
by Kurtatron - 08/22/19 10:48 AM
What are these two things in the bumper?
by atikovi - 08/22/19 09:48 AM
Amsoil Metal Protector
by Snagglefoot - 08/22/19 09:07 AM
PTL, vdubw, NJ01MGM, Antiquity, tundraotto
69034 Registered Users
45 registered members (BusyLittleShop, carlprop, alchargo, cdlamb, Ag76, Bailes1992, 2 invisible), 991 guests, and 24 spiders.
Topics293,664
Posts5,044,634
Members69,034
Most Online3,532
Jul 30th, 2019
Page 8 of 9 1 7 8 9
Re: hy-per lube zinc replacement additive [Re: spasm3] #4745374 05/02/18 09:43 AM
O
oil_film_movies Offline
O
Originally Posted By: spasm3
Mola, would there be any advantage in using the hyperlube zinc replacement ester with engines that are known for fuel dilution?
I like that question. Hope Molakule thinks about that one in case there are any effects not apparent from just considering viscosity change alone. ... I've always thought that anything super-thick (Schaeffer's #132 Moly EP is 225 cSt KV100 --- very thick!!!) added to a fueled-up oil would work. STP Oil Treatment is 200 cSt KV100 for example.
The Hyperlube ZRA is moderately thick, and it should help on just a Stribeck viscosity basis alone (+1 cSt added), yet it does have that polar nature that clings & slimes the surface pretty well.
Re: hy-per lube zinc replacement additive [Re: oil_film_movies] #4745406 05/02/18 10:31 AM
MolaKule Offline
Global Moderator
Global Moderator
Originally Posted By: oil_film_movies
HyperLube ZRA has a KV100 of about 37, if I converted the MSDS's dynamic visc at 100 correctly to kinematic visc; Therefore, you get a +1 cSt boost from HyperLube ZRA at 12 oz in a 5qt sump, so it does not quite make it to a 40 weight.
Let's make a distinction here: Most of the thick oil additives such as STP Blue Bottle, HyperLube Engine Oil Additive, Motor Honey, and other similar products for oil burners are composed primarily of cheap-grade OCP Viscosity Index Improvers and only serve to thicken the oil.
A Polymerized Ester such as HyperLube ZRA IS NOT a Viscosity Index Improver and therefor DOES NOT increase viscosity (thicken the oil).
The value of a scientific theory is its ability to prompt further study, not that it has any relation to the established facts of scientific reality.
Re: hy-per lube zinc replacement additive [Re: spasm3] #4745410 05/02/18 10:37 AM
MolaKule Offline
Global Moderator
Global Moderator
Again, a product such as HyperLube Zinc Replacement Additive does nothing to thicken the oil in terms of combating "thinning" by fuel dilution or other factors.
It may help to keep the AW components from being removed at the surfaces because of it's polar nature.
Re: hy-per lube zinc replacement additive [Re: MolaKule] #4745567 05/02/18 02:01 PM
O
O
Since HyperLube ZRA polymer esters have a KV100 of about 37 cSt, then wouldn't that thicken the oil when mixed in? Not by much at 12 oz to be sure, but it will thicken it as far as I know. Widman predicts about 1 cSt thicker.
Where did you get your info that STP & other oil-burner products have any VII in them? STP makes no claim of that. The MSDS doesn't say it has anything other than detergents and ZDDP. It appears its mostly thick base oil. Any evidence for your claims?
Re: hy-per lube zinc replacement additive [Re: DanMiller] #4745946 05/02/18 07:47 PM
J
JAG Offline
J
Polymer esters have the unusual property of having a low thickening effect when mixed with less viscous PAO or mineral oil. They dont obey the usual viscosity relationship that applies to mixes.
See page 145 for more on that: https://books.google.com/books?id=vkYCvw...ity&f=false
Re: hy-per lube zinc replacement additive [Re: JAG] #4745971 05/02/18 08:05 PM
O
O
Interesting. Good book there too. Not a new book, 1999, but some cool stuff in there.
In fact, HyperLube ZRA happens to be around 37 cSt, and the chart on page 149, Figure 12 happens to about match it at 34:
Re: hy-per lube zinc replacement additive [Re: DanMiller] #4746033 05/02/18 08:52 PM
J
JAG Offline
J
Yes, the book is great. The synergy between certain lubricant additives and/or oils is amazing.
Leslie has a 2013 version of the book: https://books.google.com/books?id=9YXRBQ...ter&f=false
Re: hy-per lube zinc replacement additive [Re: DanMiller] #4746114 05/02/18 09:51 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I only ever added a slight amount of 132, I used the molabrew with LC20.
But I havent bought LC in a long while now.
Those two likely offset each other. Dont want to make my oil too viscous... Perhaps Ill run it in the lawnmower, though it will take a long time to run through it...
FWIW, it doesnt seem like anyplace carries the hyperlube zinc replacement anywhere around me at least. The closest place is an O'Reilley in CT...
Re: hy-per lube zinc replacement additive [Re: oil_film_movies] #4746174 05/02/18 10:38 PM
MolaKule Offline
Global Moderator
Global Moderator
1) I cited, "STP Blue Bottle," Motor Honey, and Hyperlube Engine Oil Treatment additive, etc,, as examples which contained OCP VII's. Viscosity Index Improvers (VII's) have molecules that affect the viscosity of the oil verses temperature.
AS I explained above, twice, Hyperlube Zinc Replacement Additive IS NOT, I repeat, IS NOT a viscosity modifier. It is a polymer ester.
2) I could care less what the MSDS' says because SDS' do not disclose all of the components in a formulation. An SDS is NOT a formula sheet.
3) Any evidence for your claims? Yes, expensive University Lab analysis. And what is your evidence to the contrary?
Re: hy-per lube zinc replacement additive [Re: DanMiller] #4746193 05/02/18 10:52 PM
MolaKule Offline
Global Moderator
Global Moderator
This additive has also been discussed on 3/16/18 in which I explained what it is:
Quote:
A copolymer is a series of seperate isomers linked together.
In the case of HyperLube Zinc replacement, it is a copolymer of alpha-olefin isomers and dibutylester isomers linked together.
The alpha-olefin isomers and dibutylester isomers are linked together via a reaction.
https://www.bobistheoilguy.com/forums/ub...ive#Post4707916
Re: hy-per lube zinc replacement additive [Re: MolaKule] #4746429 05/03/18 08:32 AM
O
O
Getting a little weird and cranky there. NOBODY said HyperLube ZRA was a VM or VII. The question had to do with viscosity mixing, like when mixing 6 cSt PAO with 10 cSt PAO, for example, just plain old mixing. Not sure why I have to spell it out for you.
AND, you missed it, but JAG already covered the topic, and cited a valid reference, try that maybe next time yourself. AGAIN, just read the stuff above.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #4746528 05/03/18 09:57 AM
MolaKule Offline
Global Moderator
Global Moderator
I didn't miss JAG's comments, I have read all the posts, and was simply adding to JAG's post.
This statement below indicated you had some misunderstandings regarding the distinction between VII chemistry and polymer esters:
AND
Just because a chemical or compound is, "Thick" in its native state doesn't mean it is going to thicken the host oil to any significant degree IF it is not a VII.
Lastly, you seem to put your faith in a SDS as if it contained more technical information than does a textbook by someone educated in chemistry, such as by Dr.Leslie.
Recommendation: Chill and read. smile
Re: hy-per lube zinc replacement additive [Re: MolaKule] #4746695 05/03/18 01:36 PM
O
O
No, you didn't address anything JAG concluded. He was talking about exactly what I was: The ability to mix oils and raise viscosity.
Again, no. Clearly, to anybody that can actually read and comprehend plain English, I was discussing oil mixing. The concept of VM VII's is a separate topic that I never brought up. That's obvious to all, as demonstrated by JAG who answered the question succinctly and with real facts.
Chill and read.
Get snarky much??? You need to get some logic training. Have a nice day, and try actually answering questions cogently from now on.
You won't just appear rude & waste everyone's time with strange statements.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #4746716 05/03/18 01:51 PM
MolaKule Offline
Global Moderator
Global Moderator
Education and cognition can sometimes be difficult for difficult people. smile
Have a marvelous day.
Re: hy-per lube zinc replacement additive [Re: oil_film_movies] #4746720 05/03/18 01:54 PM
O
O
The question had to do with viscosity mixing, like when mixing 6 cSt PAO with 10 cSt PAO, for example, just plain old mixing. Not sure why I have to spell it out for you. It doesn't have to be a VII, that's nonsense. Everybody knows (except you I guess) that you raise the KV100 of an oil if you add thicker KV100 oil, no VII's required. That is a given, and its hard to believe why you have so much trouble understanding that. Non-Newtonian effects are present in some fluids, but there is some thickening of the sump oil using Polymer Esters, just not as much as you would get with Newtonian oil.
An SDS is sometimes revealing and sometimes not. This is commonly known. A person looks in there for some info, and sometimes its there. This has NOTHING to do with Dr. Leslie, whatever your point there was. Just strange comments from you. Keep the odd logic coming.
Page 8 of 9 1 7 8 9
