Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
Some good modern rock songs
by 53' Stude. 01/19/19 03:51 PM
06 Pathfinder O2 sensor voltage sensor 1
by Bluestream. 01/19/19 03:50 PM
Honda Blue Coolants
by redhat. 01/19/19 03:49 PM
Let's talk about some of the other NHL teams
by 53' Stude. 01/19/19 03:45 PM
coolants for 1965 imperial
by ted s. 01/19/19 03:35 PM
Where to get real Dexron III ?
by das_peikko. 01/19/19 02:40 PM
Dexcool + Prestone AMAM Mix
by George7941. 01/19/19 02:31 PM
Questions about Maverik gas
by MRtv. 01/19/19 01:25 PM
Anyone Taking Superfoods ?
by Warstud. 01/19/19 12:55 PM
Permatex High Tack (80062)
by TheLawnRanger. 01/19/19 12:29 PM
A little warm down in Oz.
by Snagglefoot. 01/19/19 12:03 PM
Supertech 6607 - 7300 miles - 2017 Legacy
by MrWideTires. 01/19/19 10:21 AM
One Of The Best F-16 Performances
by billt460. 01/19/19 09:52 AM
ejmiller, _THOR_, Captmorgan2112, TreadMonster, Snachlift500
66978 Registered Users
125 registered members (53' Stude, 4WD, 69GTX, addyguy, 02z, 15 invisible), 2,032 guests, and 33 spiders.
Topics296,849
Posts4,960,074
Members66,978
Most Online2,688
Jan 19th, 2019
Page 3 of 9 1 2 3 4 9
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2788465
10/30/12 07:45 PM
10/30/12 07:45 PM
Saskatoon canada
Clevy Offline
Clevy  Offline
Saskatoon canada
I tried the link. It took me to a book. What are the cliffnotes on this stuff,or polymer esters as a whole.
Educate me please
2006 Charger RT
Miles x 2 per oil filter
Re: hy-per lube zinc replacement additive [Re: Clevy] #2788514
10/30/12 08:57 PM
10/30/12 08:57 PM
Winnipeg Manitoba
DanMiller Offline OP
Winnipeg Manitoba
I am no expert but what I read is that the Polymer Esters in the Book show they are an effective anti wear oil.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2788515
10/30/12 08:58 PM
10/30/12 08:58 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
Quote:
What is 35 cST in layman words 50 Weight ?
http://www.bobistheoilguy.com/viscosity-charts/
Scars remind us of where we have been, but do not have to dictate where we are going.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2788521
10/30/12 09:01 PM
10/30/12 09:01 PM
Saskatoon canada
Clevy Offline
Clevy  Offline
Saskatoon canada
Alright. I wonder at what ratio it has to be to be effective,and what kind of wear reduction is to be expected,and how long is it effective for.
2006 Charger RT
Re: hy-per lube zinc replacement additive [Re: Clevy] #2788537
10/30/12 09:30 PM
10/30/12 09:30 PM
Winnipeg Manitoba
Winnipeg Manitoba
hy-per lube Zinc replacement is made by either Akzo or Italian company Italmatch KETJENLUBE 135 ( Found that in a a BITOG Post ) I haven't found much about that product but it looks like hy-per lube just renames it and puts it in a fancy bottle.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2295242
http://www.italmatch.it/cm/articoli/Arese%20brochure%2001.pdf ( link was down but it up now )
www.optimal.co.th/uploads/Lube%20Oil%20News%20Vol%2011.pdf ( ketjenlube 135 )
Re: hy-per lube zinc replacement additive [Re: MolaKule] #2788544
10/30/12 09:35 PM
10/30/12 09:35 PM
Winnipeg Manitoba
Winnipeg Manitoba
I read the Viscosity Charts but don't I need to know the temp ?
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2788545
10/30/12 09:37 PM
10/30/12 09:37 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
Chemically speaking, these esters are co-polymers of alphaolefins and dicarboxylic acids which are esterified with various alcohols and are shear-stable and virtually smokeless.
I have spoken about these esters previously as those esters which aid in the reduction of ZDDP content and do not show up in VOA/UOA's.
There is one oil mfg that's using these esters with PAO and has no ZDDP whatsoever.
Re: hy-per lube zinc replacement additive [Re: MolaKule] #2788561
10/30/12 09:52 PM
10/30/12 09:52 PM
Winnipeg Manitoba
Winnipeg Manitoba
I have read that Ketjenlube is used in German Castrol 0W30 I am not sure how true that is but I read it in a few places. It sounds like Hy-per Lube Zinc Replacement is a safe product to use they recomment 12oz per 4-6 quarts I am not sure if adding more would benefit or not ?
Re: hy-per lube zinc replacement additive [Re: MolaKule] #2788573
10/30/12 10:03 PM
10/30/12 10:03 PM
Saskatoon canada
Clevy Offline
Clevy  Offline
Saskatoon canada
Now that is interesting info.
So that nameless company is using something similar to this additive to eliminate the use of a different anti-wear compound.
The more info that comes up on this stuff the more I think I'd like to have a used oil analysis done with this stuff in the oil.
Maybe I'll test mule my mustang next year. I tracked the car on test and tune nights here and ran the street legals,so I don't know that I could get consistent info to compare it against because each interval may or may not see track time.
Dermapaint offered to try it out however he wasn't interested in sending a sample in for analysis.
The new mustang engine hasn't been treated with anything yet so it would be the perfect candidate,because no mos2 in it yet possibly skewing the results.
K boys. I'll run it in my mustang next spring. Blackstone must have universal averages for a ford 4.6 4v so I'll run an interval of pyb and this stuff and compare it to the universal averages that blackstone has for this engine and we can see whether it benefits anything.
2006 Charger RT
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2789099
10/31/12 01:19 PM
10/31/12 01:19 PM
Northern California, USA
Loobed Offline
Loobed  Offline
How does the hyper lube zinc replacement additive compare to Schaeffer's #132 Moly E.P. Engine Oil Treatment.
Engine: 2001 GM 5.3L LM7
Current Fill: Valvoline Synpower 5w-30 w/Pure-One PL25288 filter
I.M.N Oil Enthusiast
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2789426
10/31/12 06:58 PM
10/31/12 06:58 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
The kinematic viscosities at 40 and 100C are listed on the left side of the chart.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2790201
11/01/12 03:28 PM
11/01/12 03:28 PM
South Carolina
bmwtechguy Offline
bmwtechguy  Offline
South Carolina
I think the Schaeffer 132 is a good bit more viscous product and contains more Antimony anti-wear compounds than Moly, from what I have read. It supposedly contains some type of polymerized esters in it's mix as well, which i am sorta guessing is the type of compound they call their "Penetro" component. I think the Schaeffers cost me about $5 or $6 or so a bottle (by the case) and I have used it to beef up the anti-wear and viscosity of lesser oils. I think it helped a bit with the oil consumption on the 2001 Isuzu Trooper I put it in this summer with some older Castrol Syntec 10W-40 we were trying to use up. I actually would rather use Schaeffer oil instead of using additives to beef up other oils, but in this case it worked well. Got that 5 qt jug of Syntec 10W-40 on clearance at WM a few years back and it was just sitting around getting dusty. Haven't used the Hyperlube stuff yet. With the Schaeffers oil, I really don't see a need for it.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2790289
11/01/12 05:00 PM
11/01/12 05:00 PM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
As far as I know from speaking with their techs, this stuff has NO particulate type AW, or FM additives AT ALL in it.
It is TOTALLY the aforementioned KetJenLube (#9233 I believe?), polymer ester compound.
2016 Ford Fiesta ST 14K miles
Ravenol DXG 5W-30
Amsoil Ea15K51 filter
Ravenol MTF-2 in the IB6 transaxle
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2790398
11/01/12 07:01 PM
11/01/12 07:01 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
It is no secret.
Do a search on "FUCHS."
Re: hy-per lube zinc replacement additive [Re: OilNerd] #2791007
11/02/12 02:41 PM
11/02/12 02:41 PM
Staffs, UK
Brit33 Offline
Brit33  Offline
Staffs, UK
Originally Posted By: OilNerd
Be careful if you use zddplus, as it is VERY concentrated.
I was playing around with it and SuperTech Full Syn and got Zn 1859 and 1860 ppm on two batches, when mixed 60ml to 5 quarts. crzy
wow that is strong.
I added 30 ml only of zddpmaxx to 4.5 quarts recently to a baseline of 990 ppm of zinc.
Without testing I'm assuming it wouldn't raise it more than 1500 ppm.
(FYI - no high zinc level oils here where I live and I can't import any so an additive was the only option)
