CV Joint Leaking Grease
by 92saturnsl2 - 08/22/19 10:20 PM
Craftsman 6 pc. Screwdriver Set $12.14
by Warstud - 08/22/19 09:32 PM
Got My ATF Replaced.
by Mr_Luke - 08/22/19 09:20 PM
Wht do people with labor intensive jobs lay on their back?
by motor_oil_madman - 08/22/19 09:14 PM
Date code 5 Q Chevron location?
by Onetor - 08/22/19 08:06 PM
Confused, what oil to use?
by BelAir - 08/22/19 08:00 PM
2015 KIA optima turbo Coolant Flush
by Grambo - 08/22/19 07:52 PM
Motul 300V -- oops
by xr650boy - 08/22/19 06:35 PM
Evolution of Garbage Trucks...joke thread
by GumbyJarvis - 08/22/19 05:57 PM
What is this Oil's Application?
by MolaKule - 08/22/19 05:19 PM
Ford 2.5L Engine and 6F35 Transmission
by drh214 - 08/22/19 04:57 PM
Fram XG7317 vs XG3593A
by gamefoo21 - 08/22/19 03:59 PM
Carquest premium 85334
by SlavaB - 08/22/19 03:47 PM
Oil for a Ford 2.8 L Cologne V6
by ford4wd08 - 08/22/19 03:46 PM
Good Question?🤔
by Mad_Hatter - 08/22/19 01:40 PM
Autozone misinformation?
by NavyVet88 - 08/22/19 11:23 AM
Did I mess up getting a civic that sat?
by Kurtatron - 08/22/19 10:48 AM
What are these two things in the bumper?
by atikovi - 08/22/19 09:48 AM
Amsoil Metal Protector
by Snagglefoot - 08/22/19 09:07 AM
AF_VET, oilq, Nesss, Robto, Chaparro_trucker
69028 Registered Users
60 registered members (bbhero, aquariuscsm, ABCarr, Astro14, AndyB, AC1DD, 4 invisible), 1,351 guests, and 23 spiders.
Topics293,664
Posts5,044,619
Members69,028
Most Online3,532
Jul 30th, 2019
Page 2 of 9 1 2 3 9
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2786653 10/28/12 07:09 PM
Clevy Offline
I've got 5 bottles of this in my basement. When I emailed the company about using it in a shared sump bike they said not to. I've used it in my mustang and truck with no noticeable running differences or fuel economy increases.
They told me it's sone kind of polymer blend that coats metal creating a super slick surface. Mos2 works better and costs less. At least the mos2 showed a fuel economy increase.
I never did a uoa so I cannot comment on wear rates. It is very thick in the bottle
2006 Charger RT
Miles x 2 per oil filter
Re: hy-per lube zinc replacement additive [Re: Clevy] #2786662 10/28/12 07:16 PM
L
Loobed Offline
L
How much hyper lube did you put in the engine and how much MOS2 did you use?
Re: hy-per lube zinc replacement additive [Re: Clevy] #2786686 10/28/12 07:34 PM
DanMiller Offline OP
What brand of Mos2 did you use Lubro Moly ?, I tried it (Lubro Moly ) and I didn't notice any differences to be fair I didn't leave it in that long. Also how much did you use ?
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2786688 10/28/12 07:36 PM
Clevy Offline
I tried the hyper lube when I first bought my mustang so around 4 years ago. I didn't discover mos2 until about 2 years ago.
So it was about 2 years apart in treating the mustang.
I used a full bottle of the hyper-lube,and a full can of mos2.
2006 Charger RT
Re: hy-per lube zinc replacement additive [Re: Clevy] #2786690 10/28/12 07:39 PM
Do you ever to UOA are your wear number lower
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2786761 10/28/12 09:04 PM
MolaKule Offline
Global Moderator
Global Moderator
Quote:
Hi I just read that Hy-per Lube was started by Howard Hilton in the 1950's and there is a Howard Hilton that is President on Internation Lubricatants Inc ( Lubegard ) It could be there is no relation today but it interesting...
Where did you read that?
Frank Erickson is the founder and CEO of ILI.
What IS interesting is that both companies are headquarted in Seattle.
However, Seattle has been know to be the home of many entrepeneurs.
The value of a scientific theory is its ability to prompt further study, not that it has any relation to the established facts of scientific reality.
Re: hy-per lube zinc replacement additive [Re: MolaKule] #2786775 10/28/12 09:23 PM
http://www.hyperlube.com/About-Us-c2.html Harold Hilton Started Hy-per Lube and this link http://www.manta.com/g/mmdsnnl/harold-hilton shows Harold Hilton as International Lubricants Inc. President not sure how current that is or if its the same person.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2786792 10/28/12 09:45 PM
Clevy Offline
No. I never got any uoa done. It was before I even knew they existed,before I knew of this site.
Maybe next year,since I still have some however my mustangs new engine will not be much of a test mule considering as soon as I fire the engine I'm going to use cera-tec,then on the next oil change a bottle of mos2,then half a can of mos2 until the next cera-tec treatment is due.
Going to do the same in the Harley,maybe I can use my winter truck as a test mule however it only gets used when the snow flies. And I've already used mos2 in it,with a fuel economy increase.
Now that I've found mos2 I don't know that I need to use anything else. Mos2 is also cheaper per treatment than the hyper lube.
If someone wants to do a run of this stuff in their vehicle as a test subject I'll mail them a bottle,if they will post their personal results as in a before and after type deal.
2006 Charger RT
Re: hy-per lube zinc replacement additive [Re: Clevy] #2786800 10/28/12 09:52 PM
demarpaint Offline
PM sent.
God Bless Our Troops
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2786810 10/28/12 10:03 PM
Clevy Offline
I used the liqui-moly brand. You have to leave it in for the whole interval. It takes time to plate the metal surfaces and needs heat and pressure to work.
In my experience with mos2 fuel economy was unaffected until the 3rd tank of fuel. I keep track of mileage of every tank of fuel in all of my vehicles. My mustang and truck both saw a mileage increase of 1km per liter of fuel averaged over the entire tank.
I've got multiple iPhone apps to calculate mileage. I always calculate it on fuel put in against kms driven.
While driving to BC I got 650kms from a single tank of fuel all highway in the truck. Average was always 450 with mixed city/highway.
It is noticeable when I don't use the mos2. If I use it,then run out the interval,then new oil with no mos2 fuel mileage gradually declines back to 450 a tank by the end of the untreated oils change interval. It works well enough that everytime I see it I buy it because it's very hard to find.
2006 Charger RT
Re: hy-per lube zinc replacement additive [Re: Clevy] #2786822 10/28/12 10:14 PM
I found it (Lubro Moly) in Winnipeg in my local NAPA , I had to ask for it as they keep in in the back and not out on display. I think it was around $8 for 10oz (300 ML ) . I have read that some people only use around 2 OZs ( 60 ML ) per oil change.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2786903 10/29/12 12:15 AM
I found an interesting link that describes Polymer esters ( hy-per lube Zinc Replacement )
Click on the link then click on the Chapter 5 in the table of contents
http://books.google.ca/books?id=g3v3MXzJ...p;q&f=false
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2788371 10/30/12 06:32 PM
MolaKule Offline
Global Moderator
Global Moderator
That link didn't work for me.
I looked at some HyperLube at our local O'Reilly's yesterday and it appears to be about a 35 cSt oil.
Re: hy-per lube zinc replacement additive [Re: MolaKule] #2788426 10/30/12 07:58 PM
L
Loobed Offline
L
At the top of the page, next to the word GOOGLE, it will say "what is polymer Ester Oil." Click on the blue box with the magnifying glass icon. The google search page will come up, and the first thing listed is a purple book. Click on that and it will bring up the right page. The Polymer Ester is under section 5.3.3. You may need to scroll up the page a little.
Re: hy-per lube zinc replacement additive [Re: MolaKule] #2788440 10/30/12 08:11 PM
http://books.google.ca/books?id=g3v3MXzJEZsC&printsec=frontcover#v=onepage&q&f=false
Hopefully this link is Better.
What is 35 cST in layman words 50 Weight ?
Page 2 of 9 1 2 3 9
