Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
Some good modern rock songs
by 53' Stude. 01/19/19 03:51 PM
06 Pathfinder O2 sensor voltage sensor 1
by Bluestream. 01/19/19 03:50 PM
Honda Blue Coolants
by redhat. 01/19/19 03:49 PM
Let's talk about some of the other NHL teams
by 53' Stude. 01/19/19 03:45 PM
coolants for 1965 imperial
by ted s. 01/19/19 03:35 PM
Where to get real Dexron III ?
by das_peikko. 01/19/19 02:40 PM
Dexcool + Prestone AMAM Mix
by George7941. 01/19/19 02:31 PM
Questions about Maverik gas
by MRtv. 01/19/19 01:25 PM
Anyone Taking Superfoods ?
by Warstud. 01/19/19 12:55 PM
Permatex High Tack (80062)
by TheLawnRanger. 01/19/19 12:29 PM
A little warm down in Oz.
by Snagglefoot. 01/19/19 12:03 PM
Supertech 6607 - 7300 miles - 2017 Legacy
by MrWideTires. 01/19/19 10:21 AM
One Of The Best F-16 Performances
by billt460. 01/19/19 09:52 AM
ejmiller, _THOR_, Captmorgan2112, TreadMonster, Snachlift500
66978 Registered Users
124 registered members (2004tdigls, 53' Stude, 4WD, 69GTX, 02z, 15 invisible), 2,020 guests, and 34 spiders.
Topics296,849
Posts4,960,074
Members66,978
Most Online2,688
Jan 19th, 2019
Page 1 of 9 1 2 9
hy-per lube zinc replacement additive #2786001
10/28/12 01:23 AM
10/28/12 01:23 AM
Winnipeg Manitoba
DanMiller Offline OP
Winnipeg Manitoba
hi anyone use the hyperlube zinc replacement additive
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2786004
10/28/12 01:53 AM
10/28/12 01:53 AM
Mn
Lead Shoes Offline
Lead Shoes  Offline
Mn
No, but I have seen it on the shelf at O'rileys for a while and wondered the actual composition, anyone got a UOA?
1999 BMW M3 109k
Castrol 0w40/Mahle
2013 328ix 78k
PP 0w40/Mahle
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2786047
10/28/12 06:08 AM
10/28/12 06:08 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
If I had a flat tappet engine that needed additional zinc I would use Amsoil ZROD oil rather than an additive.
2015 Ford F250 w/Powerstroke
Re: hy-per lube zinc replacement additive [Re: Donald] #2786057
10/28/12 06:30 AM
10/28/12 06:30 AM
MN
Turk Offline
Turk  Offline
MN
Agreed.
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2786082
10/28/12 07:08 AM
10/28/12 07:08 AM
Utah
ddtmoto Offline
ddtmoto  Offline
Utah
I dont recall it having any real zinc in it. Redline or zddplus, zddpmax is actual Zinc and phos..
Mustang GT 5.0 Brembo '11
ram 5.9
TL1000S
GSXR1000
DRZ400E
'09 GTZ1400 Concours
Re: hy-per lube zinc replacement additive [Re: ddtmoto] #2786099
10/28/12 07:42 AM
10/28/12 07:42 AM
Plattsburgh, NY
OilNerd Offline
OilNerd  Offline
Plattsburgh, NY
Be careful if you use zddplus, as it is VERY concentrated.
I was playing around with it and SuperTech Full Syn and got Zn 1859 and 1860 ppm on two batches, when mixed 60ml to 5 quarts. crzy
Buddy's Wife: "Why do you need to get a V-8 Mustang?"
Buddy: "Because I can't get a V-12 Mustang!"
Re: hy-per lube zinc replacement additive [Re: ddtmoto] #2786119
10/28/12 08:02 AM
10/28/12 08:02 AM
Northern California, USA
Loobed Offline
Loobed  Offline
Or Crane Cams Break in Lube
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2269196
I can confirm that adding 9ml (0.3 oz) of this break in lube to 6 quarts of oil will raise zinc by 200 ppm
Engine: 2001 GM 5.3L LM7
Current Fill: Valvoline Synpower 5w-30 w/Pure-One PL25288 filter
I.M.N Oil Enthusiast
Re: hy-per lube zinc replacement additive [Re: Loobed] #2786319
10/28/12 11:48 AM
10/28/12 11:48 AM
Winnipeg Manitoba
Winnipeg Manitoba
Hi Sorry I should have mentioned the Hy-Per Lube Zinc Replacement doesn't have an Zinc in it. Its a Synthetic Ester Based Product that claims to work better than ZDDP based on Independant testing. I have looked on the Interent and on BITOG and I can't find that much information on it. The company has been around for 50 years or so yet not much information. They make a Coolant Wetter product that seems to be much more popular.
If I was looking to add ZDDP I would buy the Lucas Break In additive as I have heard that is a good product.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2786419
10/28/12 02:09 PM
10/28/12 02:09 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
I have used this kind of polymer chemistry in reduced ZDDP (experimental) formulations and I found I could reduce viscosity and still lower wear rates.
Suggested dossge ratio is about 1oz Hyper:13oz PCMO so what I suggest (since I don't see any viscosity or VII data) is adding 2-3oz of this stuff to a quart of oil and have the mix analyzed to make sure the VOA viscosity is still in the 0w20 range or whatever range of oil viscosity you may be using.
The polymer ester I use is about 140 weight (approx. 35 cSt) in its virgin form, but I suspect this stuff is "cut-down" to a 20 or 30 weight.
Scars remind us of where we have been, but do not have to dictate where we are going.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2786434
10/28/12 02:30 PM
10/28/12 02:30 PM
NY
demarpaint Offline
demarpaint  Offline
NY
It seems like it's similar to Lubegard Biotech Engine Protectant.
God Bless Our Troops
Re: hy-per lube zinc replacement additive [Re: demarpaint] #2786477
10/28/12 03:38 PM
10/28/12 03:38 PM
Winnipeg Manitoba
Winnipeg Manitoba
Hi yes it seems similar to Lubegard but I can't get Lubegard Biotech in my area. I am hoping this is just as good but there isn't that much information on it.
Re: hy-per lube zinc replacement additive [Re: MolaKule] #2786484
10/28/12 03:46 PM
10/28/12 03:46 PM
Winnipeg Manitoba
Winnipeg Manitoba
Hi what polymer Ester do you use ?
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2786501
10/28/12 04:02 PM
10/28/12 04:02 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
I don't reveal the type or source.
I am confident the LubeGuard LXE esters and the HyperLube polymer esters are NOT the same chemistry.
The one thing that we should question with any additive of this type is how the Mfg. determined the dosage levels considering they both say their third-party-additives (TPA) can be used in conventional, Blends, and full synthetic oils?
Hopefully, they did extensive testing.
Re: hy-per lube zinc replacement additive [Re: MolaKule] #2786537
10/28/12 04:34 PM
10/28/12 04:34 PM
Winnipeg Manitoba
Winnipeg Manitoba
Hi I just read that Hy-per Lube was started by Howard Hilton in the 1950's and there is a Howard Hilton that is President on Internation Lubricatants Inc ( Lubegard ) It could be there is no relation today but it interesting...
Re: hy-per lube zinc replacement additive [Re: MolaKule] #2786634
10/28/12 05:51 PM
10/28/12 05:51 PM
Loobed Offline
Loobed  Offline
So Hy-per lube isn't just another Lucas type oil stabilizer?
Page 1 of 9 1 2 9
