Fed ex
by Chris142 - 12/15/19 05:53 PM
Topics298,855
Posts5,142,666
Members70,138
Most Online3,589 Nov 2nd, 2019
UOA article - what is "normal"
#2780790
10/23/12 03:59 AM
dnewton3
OP
Global Moderator
OP
Global Moderator
Posts: 8,300 |
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters. - under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan - over maintaining something has never been proven to be anything but a waste of time and money
Re: UOA article - what is "normal"
[Re: dnewton3]
#2780862
10/23/12 07:10 AM
A_Harman
Posts: 7,631 |
Is that an article that you have just posted, or has it been on BITOG for a while? Regardless, thanks for the educational read!
2008 Dodge Ram 3500 diesel/G56 1985 Z51 Corvette track car 355/6-speed 2002 Camaro Z28 LS1/6-speed 2001 Dodge Ram 2500 diesel/NV4500+GV 1972 GMC 1500 shortbed project truck 307/SM465
[Re: dnewton3]
#2780889
10/23/12 07:41 AM
Samilcar
Posts: 1,478 |
[Re: A_Harman]
#2781094
10/23/12 10:35 AM
dnewton3
OP
Global Moderator
OP
Global Moderator
Posts: 8,300 |
Is that an article that you have just posted, or has it been on BITOG for a while? Regardless, thanks for the educational read! Wrote the bulk of it this month on vacation; been in editing and formatting for about a week.
[Re: dnewton3]
#2781368
10/23/12 02:27 PM
ltslimjim
Posts: 5,682 |
Very nice.
92 Civic Hatch (stolen  RIP) 07 Honda Fit Sport (A/T) WELCOME
[Re: dnewton3]
#2781508
10/23/12 04:49 PM
DanMiller
Posts: 121 |
Very good article, what oil do you like based on all of the UOAs you have seen ? Are you a thick or thin oil believer ?
[Re: dnewton3]
#2781539
10/23/12 05:19 PM
OVERKILL
Posts: 40,793 |
Excellent article
2019 RAM 1500 Sport - Mobil 1 EP 0w-20, FRAM Ultra 2020 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
[Re: dnewton3]
#2781562
10/23/12 05:35 PM
JAG
Posts: 5,320 |
Thank you for the great article, Dave!
[Re: dnewton3]
#2781611
10/23/12 06:12 PM
buster
Posts: 32,607 |
Thanks Dave!
2019 Frontier Pro 4X - RGT 5w30 2019 Impreza Sport - OE fill
[Re: dnewton3]
#2781850
10/23/12 11:35 PM
DanMiller
Posts: 121 |
Since leaving Oil in longer is better for wear numbers would it make sense to change the Oil filter in between Oil changes ?
[Re: dnewton3]
#2781854
10/24/12 12:12 AM
Clevy
Posts: 9,783 |
That was a great article. Very enlightening. Wear rates going down as the oil gets more miles was very informative. Thank you for the enlightening information.
2006 Charger RT Miles x 2 per oil filter
[Re: dnewton3]
#2782578
10/24/12 05:13 PM
fdcg27
Posts: 17,057 |
Really informative. We here tend to get all excited about small differences in wear metals per thousand miles, but you have put it in perspective. Maybe the only real use of UOAs is to find gross anomalies, like coolant leaking into the engine oil, or TBN and TAN as well as shear to determine oil life.
18 Accord Hybrid 20K HGMO 0W-20 17 Forester 30K VME 0W-20 12 Accord LX 115K SSO 0W-20 09 Forester 119K M1HM 5W-30 96 Accord LX 104K T5 10W-30 95 318i
[Re: DanMiller]
#2782700
10/24/12 06:50 PM
Quattro Pete
Posts: 38,319 |
Since leaving Oil in longer is better for wear numbers would it make sense to change the Oil filter in between Oil changes ? Why? Filter efficiency increases with age/miles as well. Only if you have a seriously sludged up engine that you should change filter more frequently, but then you should not be running extended OCIs either.
✰ 2002 530i ✰ 2015 Q5 3.0T ✰ 2018 Charger SRT
[Re: Quattro Pete]
#2782944
10/25/12 12:22 AM
HTSS_TR
Posts: 19,528 |
Since leaving Oil in longer is better for wear numbers would it make sense to change the Oil filter in between Oil changes ? Why? Filter efficiency increases with age/miles as well. Only if you have a seriously sludged up engine that you should change filter more frequently, but then you should not be running extended OCIs either. I agree. I'm thinking about leaving cartridge oil filter in the E430 for 2 OCI's of 10-12k miles each OCI. I will inspect the oil filter carefully on the next oil change and re-use it if the filter is in good shape and I don't see any debris. The capacity of the fleece filter is more than 10 grams, it is not possible for the engine to generate more than 2-3 grams in 10k miles.
'00 MB E430 '04 Honda S2000 '06 Volvo V70 '14 Honda Accord LX "Throwing food away is like stealing it from the poor and hungry" Pope Francis
[Re: dnewton3]
#2782965
10/25/12 03:52 AM
dnewton3
OP
Global Moderator
OP
Global Moderator
Posts: 8,300 |
The only way to know for sure it to get some PCs done (particle count analysis).
However, I would contend this; the OEM typically is as conservative with the FCI as they are the OCI.
There are a few notable exceptions. One such example is my (new to me) 2000 Galant with 2.4L engine. The "normal" OCI is 7.5k miles and the FCI is every other oil change, hence every 15k miles. That is with any filter that meets their OEM specs. And there are a whole host of filters from Purolator, Wix, Fram, etc that meet/exceed those specs, right on Wally's shelf. I am not saying all FCIs can be extended that far, but I am saying that as long as your UOA is showing good lube and engine health, the FCI should be able to at least go as long as the OCI. Only if your soot/involubles/oxidation were the drastically escalate in the UOA, would it indicate a need for FCI.
For my vehicles in warranty, (which I'm now down to only one), I am following the OEM criteria for O/FCIs. But for my other stuff, I'm beginning to push even the "normal" OCIs out and using the same filter for that duration.
I am going to put my money where my mouth is, too. I have an upcoming trip out west; we'll be taking my 1995 Villager that has 225k miles on it, and an estimated 6k on the oil by the time we leave. I expect it will have near 10k miles on the lube when we return. I look forward to seeing the UOA when I get back. Am I nervous? You bet I am; I'm always nervous a bit when I try something new. But I have faith in my data streams and SAE studies I've read. This is solid science; just because it's hard to believe, do not make it untrue.
