Originally Posted By: fdcg27
None of this is likely to help a Saturn engine.
All of this has been tried by members of the various Saturn forums and nothing really seems to help.
With a Saturn engine, as long as the owner keeps oil in it, it will run for a very long time.
High consumption is just a part of the location of the rings too high on the piston.
No oil will help with this.
Not true.
There are high mileage Saturn owners that have used synthetic oil from the start and do not have high oil consumption.
What is true, is that once you have clogged up oil control rings, they can be devilishly difficult to clean up. Nevertheless, if you want to make any progress at all in solving the problem only synthetic oil should be used.
Not true.
