I have a PC with ASUS P4P800S-X motherboard and I would like to add a larger hard drive. It works fine but the 160 GB IDE drive is pretty much at capacity. The board's user manual states that the current serial ATA interface allows up to 150 MB/s data transfer rate. My understanding is that I can use a SATA2 (3 Gb/s) drive with this board if I select the 1.5 Gb/s jumper.
However, only SATA3 (6 Gb/s) drives seem to be commonly available and the local computer shop tells me that they've had success with using SATA3 drives in similar boards in the past. I thought SATA3 drives only had 3 GB/s jumpers. The Seagate Barracuda Product Manual mentions "speed autonegotiation" but doesn't go into details.
I was thinking about getting a 500 GB SATA drive and using the 160 GB IDE drive for backups. Any advice?
