The gremlin is back. About the time I think I've slayed this dragon, she rears her ugly head once again.
I think the code is P0455.
First, does your empty tank emit a WHOOSH when you open it to refill? Mine stopped doing this a long time ago..so long I can't remember when. I remember mentioning this to my mechanic, but he asked about the gas cap. That was too easy to check. I had it done at an inspection station. OK.
I spent half a day on this last year, using a small air brush compressor, checking valves, hoses, the charcoal canister, the tank. I pressurized the fuel tank with air and heard it stretch. Thus I assumed one of the many hoses on top were not rotten. I removed the charcoal canister and both pressurized & pulled a vacuum on it. I have not dropped the tank for a visual inspection.
I attempted to make a quickie smoke tester with some incense in a jar as the air source to the pump. But the smoke wasn't dense enough coming out to rely on sight, so I listened for hissing noises and sniffed for incense. No joy. I didn't want to drop the tank unless I heard hissing.
I discovered the valve on the fan shroud would fail to hold vacuum when driven with a repetive one second pulse. I replaced it with a new one, the CEL cleared and all was well for several months.
But now the dreaded P0455 dragon is back and I'm stumped. I'm thinking to let my mechanic take a crack at this since he (a) has a lift and (b) a smoke machine.
I also wonder if a leak in this sytem could affect gas mileage. Any ideas?
Anyone dealt with this code before? What worked for you?
