NAPA Presents: A Concert Behind Prison Walls
by GumbyJarvis. 07/15/19 11:35 PM
2019 Dodge Ram Warlock
by buster. 07/15/19 11:04 PM
2014 VW Jetta - transmission service
by gregk24. 07/15/19 10:09 PM
I wish my Camaro was this color!
by clinebarger. 07/15/19 09:19 PM
2019 Crosstrek 2500 Mile Review
by Al. 07/15/19 09:00 PM
Panasonic Cockpit Radio
by dishdude. 07/15/19 08:36 PM
97 Honda Civic won't crank
by Merek. 07/15/19 08:22 PM
Farmall alternator
by chilson450. 07/15/19 08:19 PM
30K and Hyundai ATF?
by flinter. 07/15/19 07:43 PM
'03 Suburban Quirks
by A_Spruce. 07/15/19 06:51 PM
new clutch shop $1500
by sirgerman. 07/15/19 06:45 PM
Pain in the rear transmission service...
by 14Accent. 07/15/19 06:38 PM
Longer Canister Fram Ultra Part #?
by gwarrior4u. 07/15/19 06:27 PM
Rats! I need bodywork
by PeterGreen. 07/15/19 06:15 PM
ATF-4?
by WillB. 07/15/19 05:58 PM
Rotunda AOD Transmission Rebuild Tool Kit
by TooManyWheels. 07/15/19 04:44 PM
No more Champion plugs for me LOOK!
by bchannell. 07/15/19 04:11 PM
Lucas_Jones, cobb_cruiser, robinjeter, SpicySenpai, Weatherdriver77
68669 Registered Users
48 registered members (Bailes1992, A_Spruce, AC1DD, Ammofirst, 1WildPig, 928, 5 invisible), 986 guests, and 27 spiders.
Topics291,925
Posts5,013,434
Members68,669
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Leaking oil with AutoRX #275143
06/04/04 04:37 AM
06/04/04 04:37 AM
MN
T-Keith Offline OP
T-Keith  Offline OP
MN
I started my autoRX treatment on Sunday. Unfortunately I noticed an oil spot on the driveway when I got home. I've leaked 3/4 of a quart in the first 400-500 miles. I'm worried about loosing all the AutoRX before the treatment is over(1500 miles). My capacity is only 3.5 quarts.
It's leaking at the oil plug/filter cover. It's never had a problem before and I even replaced the gasket a couple oil changes ago. [I dont know]
I was hoping to get a good before and after example of AutoRX, and this apears to be screwing things up. [Mad]
Any ideas?
-T
Re: Leaking oil with AutoRX #275144
06/04/04 05:45 AM
06/04/04 05:45 AM
USA
JohnBrowning Offline
USA
Temp. fix. Clean the drain plug area very well with a fast evaporateing solvent. Take some RTV and pack it around the drain plug with it in place. This might not fix it but it is worth a try.
Are you sure it is not cross threaded and that it is snug? Maybe and extra 1/8of a turn is it is not already over tight could also solve it.
I would not sweat it too much. The origanal instruction for AUto-Rx only called for 500 miles anyway so it is not like it is a total waste.
Re: Leaking oil with AutoRX #275145
06/04/04 06:05 AM
06/04/04 06:05 AM
MN
T-Keith Offline OP
T-Keith  Offline OP
MN
It's a 2&1/2 inch dia. plug, it can't be crossthreaded. I tried tightening it, but it was already very tight.(12" long, 15/16" wrench) I still bothers me that it's leaking, since this is somthing it really hasn't done before. [I dont know]
I may actually try the RTV thing. Here's my before pics BTW:
http://www.lesabret.com/rx1s.jpg
http://www.lesabret.com/rx2s.jpg
-T
Re: Leaking oil with AutoRX #275146
06/04/04 05:14 PM
06/04/04 05:14 PM
Austin, TX
427Z06 Offline
427Z06  Offline
Austin, TX
I'm a little slow this morning. What is an "oil plug/filter cover"? Is this similar to the old Chevys that had a cartridge filter that fit into a canister that had a bolt through the center of canister which bolted to the oil filter boss on the block?
Does it have a washer under the head of the bolt aka oil plug? Maybe this washer is missing or damaged and the AutoRX penetrative abilities are now exploiting this?
By the way, how about a little history to go along with your pictures. Thanks in Advance.
Re: Leaking oil with AutoRX #275147
06/04/04 08:35 PM
06/04/04 08:35 PM
MN
T-Keith Offline OP
T-Keith  Offline OP
MN
It's an 88 Pontiac 2.5. The oil filter is a cartige type in the oil pan. There is no other plug, the oil is drained by removing this plug.
Here's a picture of the plug:
http://www.secureleadercom.com/fsstore/prodpics/64483.GIF
Here's a picture of the oil pan:
http://www.secureleadercom.com/fsstore/prodpics/64674.GIF
Except mine lacks the extra plug.
The car has 191,000 miles, it's had 3,000 mile oil changes since I got it. The rockers arms look worse in the picture, than the probably are, I took these pics on Sunday when replacing the valve cover gasket, before changing the oil and adding the Auto RX.
-T
Re: Leaking oil with AutoRX #275148
06/06/04 09:49 AM
06/06/04 09:49 AM
Austin, TX
427Z06 Offline
427Z06  Offline
Austin, TX
Wow. I never messed with these 4 bangers and didn't know such a thing was used on Chevy engines. I'm assuming this is the Chevy 4 banger of years gone by.
Re: Leaking oil with AutoRX #275149
06/05/04 10:00 PM
06/05/04 10:00 PM
MN
T-Keith Offline OP
T-Keith  Offline OP
MN
Re: Leaking oil with AutoRX #275150
06/05/04 10:37 PM
06/05/04 10:37 PM
USA
USA
The old iron duke was a durable engine but lacked power. The engine does not look bad at all. THeir is no thick sludge at all just a thin layer of either hard varnish and some light sludge ont op of that. Vrnish lacks carbon once you have carbon or other third party abraisve in it I call it sludge. For 191,000 miles I would say that it look ok. You can see GM cast into that head! It could look better but this is actualy rather typical of a well maintained GM product from that time frame.
Re: Leaking oil with AutoRX #275151
06/06/04 03:50 AM
06/06/04 03:50 AM
Austin, TX
427Z06 Offline
427Z06  Offline
Austin, TX
I thought this engine was derived from the 4 cylinder Nova engines of the '60s?
http://1320pi.com/ahra/art/nova.htm
[ June 06, 2004, 06:54 PM: Message edited by: 427Z06 ]
Re: Leaking oil with AutoRX #275152
06/06/04 04:06 AM
06/06/04 04:06 AM
Austin, TX
427Z06 Offline
427Z06  Offline
Austin, TX
I think there's a lot of confusion on this one.
http://www.jeeptech.com/engine/gm151.html
Re: Leaking oil with AutoRX #275153
06/06/04 04:30 AM
06/06/04 04:30 AM
MN
T-Keith Offline OP
T-Keith  Offline OP
MN
Your thinking of the 153, the 2.5 in my car is a 151. They changed numerous times over the years, but the info on the jeep site is correct, it is not the Chevy engine.
-T
Re: Leaking oil with AutoRX #275154
06/06/04 05:25 AM
06/06/04 05:25 AM
Austin, TX
427Z06 Offline
427Z06  Offline
Austin, TX
-T
My understanding is, Pontiac used the original Chevy 153 cid as a basis for designing the Pontiac 151 cid version. If you look at the bore and stroke dimensions, those are typical (not exclusive to) of inline and small block Chevys. I'm thinking this is in the same league as the Range Rover pushrod engine...a '60s Buick design bought by Range Rover and used in the '80s and '90s. It just doesn't sound like GM to approve a completely new design of a pushrod 4 cyl engine of essentially the exact same dimensions internally and externally.
However, I'm not positive on any of this so enlighten me if you are.
Re: Leaking oil with AutoRX #275155
06/06/04 06:45 AM
06/06/04 06:45 AM
MN
T-Keith Offline OP
T-Keith  Offline OP
MN
There's not alot of info out there on the Iron Duke, but here's a good page with some info.
http://webpages.charter.net/imsa_gtu/docs/HRM-SD4article.htm
The Chevy was based off an I6. The Chevy V8 came in so many configurations that they probably match up to alot of engine. To note, the Pontiac 301 has the exact same bore and stroke as the Duke.(4" bore x 3" stroke)
Yes rover bought the Buick V8 from GM since GM had a more economical alternative(the V6), they actually modified it very little, and Land Rover(owned by ford) is still using it this year.
Anyway, we may be getting a little [Off Topic!] here. Anyone know how this will affact my rinse phase?
-T
Re: Leaking oil with AutoRX #275156
06/06/04 06:52 PM
06/06/04 06:52 PM
Austin, TX
427Z06 Offline
427Z06  Offline
Austin, TX
I apologize T-Keith, my bad. I have no personal experience with AutoRX, but as a suggestion, did you try emailing Frank(?) of AutoRX to get his advice?
Re: Leaking oil with AutoRX #275157
06/06/04 10:42 PM
06/06/04 10:42 PM
Trondheim, NORWAY
raynorway Offline
raynorway  Offline
Trondheim, NORWAY
Why not just drain out everything in a clean bucket, fix the gasked and put it back in ?
Page 1 of 3 1 2 3
