Originally Posted By: 92saturnsl2
Originally Posted By: Jakegday
absolutely not. when driving "x" distance you at least have the water pump circulating water from the second you start the engine. you dont have that without a belt. Like others have stated, and agreed with, without the water pump moving you could have water boiling around your cylinders and cold water still sitting at your temp gauge. DO NOT trust the temp gauge without the water pump moving.
On to your original question, i wouldnt go more then a mile or so. And i would be gentle to her in that mile.
Pure nonsense. Without the thermostat open, the water pump isn't circulating much of anything. The coolant temperature in the different areas of the engine will normalize itself through natural convection.
Also, don't you think the engineers had it in mind to warn the operator even if the pump has failed? The coolant temperature sensor will read correctly regardless of whether the pump is working.
Running the car with the belt off, absolutely is a fine way of diagnosing noises in the accessory drive as long as you use your head and don't operate it too long that way.
Incorrect, if you actually study cooling water paths, you see the thermostat doesn't STOP water flow, it reDIRECTS it for faster warmup and quicker heat to the heater core.
