I've been looking at the Cooper AT3 tire next on my f150, in 275/65/18. The truck came from the factory with load range C, how ever now that things changed a while back I do mostly all highway, a little off road, and not much towing/hauling. So I was thinking of just getting the standard load AT3 tires, for better ride and what not.
So I was comparing the specs and have a question. Why do the standard load tires have a higher max than the load range C tires?
Code:
Tire serivce load sidewall Diameter tread width max load tread depth
LT275/65R18, 113 S, C OWL 32.1 8.9 2535 16.5
275/65R18 116 T 560 A B, STD OWL 32.14 8.73 2756 13
Could having less tread depth but the same diameter enable the tire to have more air volume for a higher load or what gives?
Code:
