A few years back, I allowed myself to be convinced that XRF ball joints were among the best available for my application.
After install, just like the XRF website warned, the bottoms would not accept any grease until they worn in.
Well after 2 years, they would still not accept any grease(the zerks were not plugged) and I bought an extension for my grease gun with a needle and punctured the boot and nearly filled the boots with Redline CV-2. At this time, I was also able to get a very tiny amount of grease in through the zerks at this time, perhaps three very slow pumps with the gun each, using a lot of hand pressure.
This was about 2 weeks ago. At that time I noticed yet another boot on a Tie rod end had split, and yesterday I replaced it with a polyurethane, and then regreased all the Zerks again while I was under there, mostly to purge more of the old unknown grease and replace it with the Redline CV-2.
Much to my surprise, when I attached the gun to the lower BJ's, they provided no resistance to the gun, and each easy pump expanded the boot slightly until it started exiting the pinhole I punctured at the top of the boot.
It makes no sense to me why these ball joints decided to go from barely accepting any grease through the zerk, to no resistance what so ever, in 2 weeks and perhaps 35 miles of easy around town driving.
I do not see how filling the boot from the top via a needle through the boot would allow easy greasing from the zerk 2 weeks later.
Any theories?
Any theories?
