So in a thread many moons ago i wrote about finding the PCV valve on my 06 5.3 ltr silverado.. I found it in short order and also found out its a permanent fixture onthe valve cover.. thats right its not a replacement item unless you want to replace the entire valve cover..
With that said and 71,xxx on the motor now i decided it was time to do a little cleaning.. I removedthe hose and put the red straw into the PCV hole, i depressed the buttom on the can 3 times for short bursts.. I was suprised when i seen black liquid jump back out at me. I replaced the hose and started the motor about 60 seconds later. I let it run 2-4 minutes.
I did a OCI after this was done and put fresh oil in it..
Ive noticed no ill effects of doing this and i have no doubts that it cleaned up some of the junk in the PCV.. still wish it had a replaceable unit..
just sharing.
just sharing.
