MolaKule
Staff member
A good candidate for what?
Delo has most of what you need already formulated into the base oil.
I think it's a great product for enhancing certain low cost oils at a treat rate of 1 oz per quart " approximately " so to remain cost effective . I'm not certain more than that would produce better results anyway but at the above rate I'll get 3 oil changes out of one bottle .quote:
Originally posted by JeepZJ4.0:
Motorbike, I added a bottle of the Synpower Oil Treatment to the sump of Mopar Brand oil (probably Exxon or Mobil) and I immediatly noticed an increase in smoothness.
Today I saw the Maxlife Engine Protector at Walmart for $2.94 a bottle.quote:
Originally posted by Cutehumor:
just went to a local walmart. maxlife engine protector is now $3.94 for a 15 oz bottle. dropped $1 in price
Same set of additives but less.quote:
It was never stated whether or not the Synpower Engine Treatment contained the same additives as the Max Life Engine Protector.
Whoops. Didn't see that you already had posted this over two months ago. I think you did well to use the SI-1 over the Maxlife fuel system cleaner. The Redline worked great for me.quote:
Stopped by walmart yesterday..maxlife engine protector price is now $2.94. rollbacked.
Oh, Maxlife fuel system cleaner is $2.50 for 16 oz but I just bought redline SI-1 fuel system cleaner at advanced auto parts for $5.98 15 oz
So the Synpower Engine Treatment has lower additive levels. Glad I bought 4 bottles of the Max EP at $2.94. I think I will go back for another 4 bottles.quote:
The MaxLife Engine Protector is IMHO, the better buy at $2.94.
I get 970 ppm on a 5 quart sump using 4.5 qts of oil and 0.5 qt (approx) additive:quote:
For example. Let's say for the grey bottle OTC additive, the phosphorus reading at VOA was Phos 1578, or rounded up to 1600 ppm.
Let's say your original oil's VOA showed a P of 900 ppm. Then by adding the Grey bottle contents, your final P level should be approx. 1060 ppm.
