Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
Pepboys Clearance oil SCORE!!
by Artem - 02/24/20 11:45 AM
Selling Vehicle CL / FB asking price
by madRiver - 02/24/20 11:24 AM
Cheapest place to get VOA with TBN?
by jayjr1105 - 02/24/20 11:18 AM
Selling my Mustang
by SilverGt - 02/24/20 11:05 AM
Tractor Supply more Mobil 1 clearance
by jayjr1105 - 02/24/20 10:51 AM
BG PLATINUM 44K
by UG_Passat - 02/24/20 09:51 AM
F-150 trucks in the past 10 years
by lancerplayer - 02/24/20 08:38 AM
What Fluid For Snapper Rear Axle
by Propflux01 - 02/24/20 07:25 AM
Played in the sand a little.
by Chris142 - 02/24/20 07:11 AM
oil extractors manual type
by passgas55 - 02/24/20 06:14 AM
Tesla Disrupts German Economy
by Y_K - 02/24/20 01:53 AM
Difference in Valvoline Asian red offerings?
by MichaelRS - 02/24/20 01:51 AM
RV's . give me the good and bad of owning one
by WhyMe - 02/24/20 01:36 AM
Removing silicone spray overspray/residue
by Calikura - 02/23/20 09:13 PM
Oil Questions for My New Mower
by CamBurt33 - 02/23/20 08:43 PM
2007 Vibe coolant smell
by philipp10 - 02/23/20 08:36 PM
PeterNST, SkinnRS, Bama65, wjamyers, L00btech
70793 Registered Users
112 registered members (4WD, 1978elcamino, 14Accent, andreigbs, Aero540T, alchargo, 8 invisible), 2,571 guests, and 18 spiders.
Topics301,873
Posts5,204,326
Members70,793
Page 14 of 14 1 13 14
Re: Liqui Moly Ceratec [Re: Trav] #4629363 01/09/18 02:42 PM
SHOZ Offline
Originally Posted By: Trav
What else are they going to say? That's like the wife asking do I look fat in this dress? Then the fight started.
Call me a skeptic but i am not Ray Charles, it stayed there till I physically removed it.
So re you saying you had to remove the oil pan to get it out?
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Liqui Moly Ceratec [Re: SHOZ] #4630141 01/10/18 09:07 AM
T
Trav Offline
T
I used Ceratec in a compressor not an engine that was MoS2. I could see the Ceratec in the sight glass so I pulled the side cover and cleaned it out and changed the oil.
The stuff in the oil pan I found when I changed the rusted pan otherwise I would have had no idea it had fallen out.
The greenish grey stuff is MoS2 and no it did not mix back into the oil when the engine ran, the engine ran 2 hrs before the pan drop, the oil was still warm. The chunks are pieces of gasket from the tube that got knocked in taking it off.
Re: Liqui Moly Ceratec [Re: eta] #4630147 01/10/18 09:10 AM
SHOZ Offline
^^^ The engine ran for two hours, was that on the highway?
But still that's not Ceratec. shrug
Re: Liqui Moly Ceratec [Re: SHOZ] #4630200 01/10/18 09:44 AM
T
Trav Offline
T
The ceratec fell out in the compressor. The engine was running 2 hrs before I pulled the pan because that's how long it took me to get it out, I have no idea how long it ran before I forget.
No matter both product fell out of suspension, that's enough for me to avoid them or anything else that is a sold.
Re: Liqui Moly Ceratec [Re: eta] #4630584 01/10/18 02:27 PM
SHOZ Offline
I have a small inspection camera for my phone. Next spring I need to change the trans oil which has 150ml of Ceratec and will have been sitting for three months. I'll drive it a day first then drain and look inside to see what's laying around.
Re: Liqui Moly Ceratec [Re: SHOZ] #5174922 07/30/19 01:55 PM
R
Rob_C Offline
R
Were you able to use the camera you had mentioned? I'm curious if you found anything.
Re: Liqui Moly Ceratec [Re: Rob_C] #5175030 07/30/19 03:56 PM
SHOZ Offline
No I haven't and probably won't. Not concerned with it settling out. I did have my cars oil pan off this spring when I did the timing chain. No apparent buildup of the yellow Ceratec.
I've got 16k miles on the trans fluid and still as good as when I put it in shift wise.
Re: Liqui Moly Ceratec [Re: eta] #5210446 09/11/19 07:01 PM
L
Lowflyer Offline
L
Without own opinion and experiences: Why it should be "inoperative"? His "ceramic" is hexagonal Boron nitride. (α-Boron nitride). Contrary to β-Boron nitride, all wikis than I can find thereto, means, α-boron nitride is a part of lubricant solutions.
And β-Boron nitride of grind solutions laugh Therefore its significant whether α-Boron or β-Boron grin
Or that: http://technical-ceramics.3mdeutschland.de/en/products/3m-release-agents-and-lubricants.html
"Reliable insulating and protective effect, as well as good lubricating properties, even at high temperatures"
