For those of you who store your bikes over winter, do you fog the engine prior to storage? Is it really necessary?
FYI, my bike's engine is carburated. In the past I would just change the oil, put some StaBil in the fuel tank and run it a bit and store it with the tank and carbs full, no fogging. If I were to fog, I would need to pull the tank off the bike to get to the carbs which is more work than I care for, to be honest.
The bike is stored inside an attached unheated garage where the temps never fall below 40F, if that matters.
If you fog, does the fogging oil contaminate the engine oil thus necessitating another oil change when pulling the bike out of storage?
