AME 37330 Hub Cleaner for Impact Wrench
by The Critic - 11/18/19 01:54 AM
Plastic bag vs Car
by The Critic - 11/18/19 01:50 AM
Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1¢ at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0 8592 miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
Grumpy Kid
by wings&wheels - 11/17/19 01:57 PM
h9/95R FLA Batteries
by TXCarGeek - 11/17/19 01:40 PM
Preventative parking brake service
by Donald - 11/17/19 01:26 PM
JimBobSeeker, Joey737, bdavis218, XTR74, 2009Caraman
69899 Registered Users
25 registered members (FordCapriDriver, carlprop, Falcon_LS, 2000Trooper, CharlieBauer, AndyB, 2 invisible), 677 guests, and 18 spiders.
Topics297,569
Posts5,118,193
Members69,899
Most Online3,589
Nov 2nd, 2019
SEAFOAM FOR LONG TERM CLEANING? #2692973 07/23/12 02:11 PM
A
audia6 Offline OP
A
The previous owner i bought my car from used small amount of seafoam like 1 ounce in the whole 6.5 QT oil capacity.
He says he ran it for 3000 miles and the seafoam "cleans" the seals and removes the gunk and therefore the Valve covers are leaking. (which im OK WITH)
MY real question is will the engine suffer any additional damage besides the leaking valve covers?
He used only 1 and 1.5 ounce MAX for about 2000-3000 miles.
I believe seafoam calls for 1 ounce or 1.5 ounce per quart capacity.
I ask because im seeing a higher oil consumption. The cars burned 1QT of 5w-40 rotella t6 in 2100 miles.
No exhaust smokes or power loss at all.
He also said he "flushed" the seafoam with rotella t6 for 200 miles and put new rotella t6.
CAR is a 2001 passat 2.8 v6 same as audi 2.8
Re: SEAFOAM FOR LONG TERM CLEANING? [Re: audia6] #2692987 07/23/12 02:20 PM
E
EricF Offline
E
the itty bitty bit he used didn't do much.
the leaking valve covers is simply that.. they're leaking due to age, seafoam did nothing to help that.
When you change oil brands, you need to give some time for the engine to get used to a different oil.
no need to flush seafoam out, it will slowly evaporate over time anyway.
the guy had no real clue what Seafoam really can do and how to properly use it.
Just be glad he did use it a little bit.
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
Re: SEAFOAM FOR LONG TERM CLEANING? [Re: EricF] #2693002 07/23/12 02:36 PM
A
audia6 Offline OP
A
So seafoam for long term wouldnt do any damage to the internals of the engine?
I read in some places that if seafoam sits too long it can eat the seals, but that was when injected in the intake. i thought it might also eat some seals inside the engine that might cause me to rebuild the engine and causing the 1QT in 2100 Miles oil consumption.
I will check the cars PCV hoses and see if their clogged
Re: SEAFOAM FOR LONG TERM CLEANING? [Re: audia6] #2693021 07/23/12 02:59 PM
dparm Offline
If the car is getting its periodic changes with a decent oil, that sort of stuff shouldn't be necessary.
AFAIK the 2.8 is not a known sludger.
2017 Chevrolet Corvette Grand Sport
Re: SEAFOAM FOR LONG TERM CLEANING? [Re: dparm] #2693068 07/23/12 03:50 PM
A
audia6 Offline OP
A
Yea but whats done now is done. If anyone thinks this long term use of 1-1.5 ounce of seafoam can possible cause engine damage post what kind of damage is possible.
Re: SEAFOAM FOR LONG TERM CLEANING? [Re: audia6] #2693080 07/23/12 04:06 PM
A
antiqueshell Offline
A
I never stop being surprised at people will put "additives" into the fuel and crankcase systems of their expensive and critically important automotive investments without first doing a LOT of research and investigation!
You should NEVER EVER EVER EVER.....EVER use additives that are NOT specifically approved by the car manufacturer. If you insist you may well end up doing serious and or permanent damage to your car which might end up being outrageously expensive to repair.
About the only universally approved "additive" I can think of these days is fuel system cleaners with PEA, such as Techron Complete Fuel System Cleaner, and similar products. But even so I would check with the manufacturer to see what their take is on using such products. Most will be OK with PEA fuel cleaners.
Re: SEAFOAM FOR LONG TERM CLEANING? [Re: audia6] #2693090 07/23/12 04:19 PM
L
LeakySeals Offline
L
Seafoam gets its name from its original purpose, upper cylinder lube and fuel stabilizer for motor boats. People seem to think its a fix for everything. Maybe its marketing, maybe something about the name that attracts people. Maybe people put too much faith in YouTube, who knows.
Anyways one of the ingredients of seafoam is IPA. Some IPA MSDS sheets claim IPA reacts with plastic, rubber and aluminum. Others tests see no problem with it in small doses. Another ingredient is Pale oil. Why somebody would fog their cat and o2 sensors with plumes of lubricant is beyond me. Pale oil in motor oil would give a thinning effect. Some complain of ticking for a while after use. But it goes away.
Can't say what exactly caused the leaks. Miles and age matter for leaks. Not knowing how many miles, assume your gaskets have undergone some "outgassing" which is the normal aging process for rubber. Shrinks and hardens from heat and oxidation. Could be the gasket had some sludge helping plug a hole.
So..I agree with others that a good oil can do most of the work. A high mileage oil may help soften up and swell the seals. I do use additives. MMO and Kreen in the oil occasionally. But not in the oil constantly, very infrequently. Redline si-1 or techron in the gas every other OC.
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: SEAFOAM FOR LONG TERM CLEANING? [Re: antiqueshell] #2693148 07/23/12 05:21 PM
A
audia6 Offline OP
A
Funny thing about additives is I was at the dealer both VW and Audi carried ZMAX. It is meant to go in the oil, gas, and tranny. I was actually surprised vw and audi are promoting the use of these additives.
Any one hear of Zmax microlube?
Re: SEAFOAM FOR LONG TERM CLEANING? [Re: audia6] #2693338 07/23/12 08:41 PM
T
TC Offline
T
The amount of Seafoam he used represents 0.7% of the sump capacity (1.5 oz in 208 oz). I can’t emphasize enough how LITTLE significance that is to the engine, its longevity, or any potential damage done. And to assume that any damage was done is silly in itself – I’ve used MUCH larger concentrations of petro-solvents in engines before to cure lifter ticks and the like, with no harm whatsoever. Any oil burning is unlikely to be related to Seafoam use, and more likely due to its 2001 vintage. Additives like this tend to be evaporated out quickly – you can often see this within days on a dipstick after adding 16 oz of MMO, for example, should one do that. IPA and Naphtha are compatible with automotive seals/elastomers (see links). “ GM Upper Engine and Fuel Injector Cleaner” contains about 20% alcohol, more evidence of seal compatibility (link below). The amount of Pale Oil involved is of no significance to exhaust systems, and it was added to the oil, not fuel, regardless. Gaskets may leak simply because your car is 11 years old, and even synthetic oils can “cause” new leaks simply due to their cleaning ability, cleaning out junk that had made up for an old, compromised seal. For someone thinking “manufacturers’ approved” additives are made in Heaven, with everything else suspect, just read the Mopar MSDS below. (“Mopar Fuel Additive” is up to 100% diesel fuel. But it’s MAGIC “manufacturer approved” diesel fuel!)
Dude, you’re chasing an old ghost from the prior owner, worrying that it’s damaged your engine. But the ghost simply ain’t there – you’re worrying about nothing, based largely on rumors.
http://www.daemar.com/pdfs/159_DMR_MechSeal_FluidCompatibility.pdf
http://www.balseal.com/sites/default/files/tr60d_020707133101.pdf
http://paceperformance.com/attachment/37146-.pdf
http://www.wynnsusa.com/pdf/mopar%20fuel%20additive%20msds%20-%20040605.pdf
