I was about to change the spark plugs on this engine (4.6L V8 Ford) and I removed the coil/boot from the left front plug and noticed a lot of dirt buildup around it, so I used the air compressor and a blow gun to remove any debris before proceeding further.
I then unscrewed the plug, and noticed it was pretty difficult to turn almost all the way out--had me scared of a misthreaded plug. Then I noticed greasy dirt ground tightly into the threads.
Obviously the idiots who serviced the truck previously didn't bother with getting the dirt out of the way first.
My question is this: whats the best way to clean the threads in the engine? I was thinking use brake/carb cleaner liberally to soak the open hole, then turn the engine over without the plug in to get as much of the **** out of the cylinder as possible before reinstalling the plug; one at a time.
