Last yr I did a repair on a shower basin using epoxy and figerglass. After working the expoxy into the fiberglass the epoxy appeared to be thick enough and not run. I came back 5 min later and all was fine and the epoxy was 6 inches from the drain an setting up just fine. Evidently some time after that and the chemical reaction heated up the epoxy thinned some and ran down the drain after I had left. Unfortunately the shower is in the shop and plumbing buried under concrete. Drain runs slow due to the epoxy now in the pipe. Sometimes it will plug requiring plunger or draino. Tried a snake.. no good... anything I can use to get through this epoxy blockage without hurting the PVC pipe??... the blockage is in the turn about 18" down. thanks for any help!!.. Mike
