I recently acquired a 2007 Suburban 2500 6.0 with the 4L80E transmission. I had my hometown mechanic change it over to Amsoil ATL. Now it leaks at the rear left corner of the pan. The oil pan has 17 bolts around the perimeter. The Chilton manual says it will leak if the bolts are too tight. They are supposed to be 97 in lbs. I carefully checked the torque by using my torque wrench set at 8 ft lbs. It still leaks. It is not overfilled. I hesitate to just crank down on that corner bolt. Should I try to go a little tighter first and see what happens?
Thanks
Thanks
